2011 tsx brake pads
Old Nov 26, 2013 | 12:36 AM
JamesEmbry's Avatar
2011 tsx brake pads
I have about 5.5 mm left on both the front and rear pads and I have over 50,000 miles. That seems like a ton of miles for brakes. How low can you go before they need changed? Will the car letme know with a warning light?
Old Nov 26, 2013 | 10:56 AM
its rayden's Avatar
the car will let you know with a warning sound. brake pads have a metal tab that will rub on the rotors when your pads get low. when the brakes start squealing, it's time to change the pads
Old Nov 26, 2013 | 01:57 PM
ceb's Avatar
ceb
150k+ miles on a set of TSX brakes is not unheard of.
You'll know when it is time. You will hear n awful squeal when you apply the brakes - not the "car sa for a while squeal" but a loud, obnoxious noise that sounds like metal on metal (which is what it is.)
Old Nov 26, 2013 | 02:04 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
Yeah you will hear a squeal. I think 2mm is when you should replace.
Old Nov 26, 2013 | 02:27 PM
Simba91102's Avatar
Old Guy
There are two major factors that determine how long the pads will last (all things being equal, meaning comparing apples to apples). Driving style and the type of miles you put on them. Easy on the brakes and all highway miles, and they'll last forever. Use them often and hard, and drive around town a lot, then not so much. Fortunately, they're a cheap and easy swap, so I can't see that it makes much difference either way.
Old Nov 26, 2013 | 02:34 PM
nj2pa2nc's Avatar
it's a car-drive it
changed the rear brakes for the 1st time at 150K miles but still on the original fronts.
Old Dec 19, 2013 | 08:15 PM
archerandsons's Avatar
Pads are cheap so just replace if u question it. IMO
mada51589
Jan 9, 2025 04:40 PM
CatalinaILX
ILX
Oct 27, 2015 02:56 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
