2009 TSX Trunk won't open!!!
Old 04-20-2017, 10:40 PM
Garellano73's Avatar
So my trunk does not open...not with FOB, not with the button on the door and not with the button by license plate. I have checked the switch inside the glove compartment as mentioned in the blog and that is "on".
We were thinking it was a problem with the latch because we would pound on top and after some pounding it seemed to "loosen" it or something and we would press the button on the FOB/door/license plate and it would open. Now, that won't even work! HELP!!
Any suggestions??
Old 04-21-2017, 07:50 AM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
This thread has been moved from the First Generation TSX Discussion (2004-2008) > 1G TSX Problems & Fixes Forum to the forum applicable to your car.
Old 04-21-2017, 10:20 AM
julius071's Avatar
It could be the rubber seal on the trunk jamb that is causing it to stay close. Maybe spray some lubricate, I don't know what but give it a try.
Old 04-21-2017, 10:38 AM
Received 8,585 Likes on 6,631 Posts
Honda Shin-Etsu Grease is the best for those rubber seals.
julius071 (04-21-2017)
Old 04-24-2017, 10:09 AM
icu2tsx's Avatar
Any suggestions??
will it open with somebody pulling from the inside using the emergency handle?
The plastic cover that holds the latch on the bumper tends to fall-off.move easily, it could be binding and not allowing the electronic motor to open it. remove that plastic cover and see if it opens it, also the latch that is held by two screws (tends to come lose, specially after a bumper collision). If that got loose it could've thrown the alignment off causing it to not open. it moves up and down and can be easily adjusted.
julius071 (04-24-2017)
stm25rs
07-17-2017 01:25 PM
getakey
3G RLX (2013+)
06-19-2017 11:37 PM
jim_c
04-13-2017 11:39 AM
krastem
03-31-2017 09:59 AM
woodster66
4G TL Photograph Gallery
03-27-2017 09:27 AM
Quick Reply: 2009 TSX Trunk won't open!!!
