2004 TSX Timing Chain Problem
Old May 25, 2012 | 10:19 PM
CM 2004 TSK's Avatar
5th Gear
Hi Everyone,
New to forum and looking for advice/steps to a solution for Timing Chain problem for 2004 TSX 145,000klms.
Dealer diagnose:
- timing chain stretched and jumped of time gear teeth
- crank shaft and CAM shaft timing out of phase
- requires REPLACEMENT of timing chain, guides and upper and lower chain gears and tensioner.
- front row axle seal starting to leak transfluid
- oil pan gasket leaking
- engine is running very rough because time out of phase
Note:
I had troubles starting with winter starting problems and battery trouble. Hard to start in cold. Battery was replaced.
Car stalled three times in last 6 months, most recently few days ago. This latest time was the first time oil change light came on. Never came on before.
In regards to oil, I may not have been good with changes weekly, or by weekly, but rather monthly. I am a city drive and did not drive long distances. But over the last few weeks was on highway more frequently. The car was using up gas and oil very very fast.
There was a little leak of oil that my mechanic, not the dealer thought was not a big problem and let it go.
What should I do to minimize the expense? Dealer say cost will be $3K. Any and all suggestions are appreciated.
Thank you,
CM
Old May 25, 2012 | 10:21 PM
5th Gear
The lights that were on where check engine, VSA and Caution Light.
Old May 25, 2012 | 10:50 PM
odus's Avatar
you posted this in the wrong section this is second gen you have a first gen. and if your timing chain jumped and your still driving it stop thats a big no no.
Old May 26, 2012 | 12:00 PM
5th Gear
Problems & Fixes > 2004 TSX Timing Chain Problem
Thank you. will post in first gen. I've stop driving. car is at the shop.
AndrewS
19
Mar 14, 2024 06:59 PM
redman333
Oct 9, 2015 10:12 AM
Gianni Formica
Sep 7, 2015 08:28 PM
Redsand353
Sep 6, 2015 01:03 PM
jordanboi
Sep 5, 2015 01:33 AM
