03 Acura TL Driveability issue
Old Jan 9, 2013 | 09:01 AM
uptop's Avatar
5th Gear
Hello,
I have a 2003 Acura TL. I just had the transmition replaced & the very next day I had an issue leaving the house. When going slow through a parking lot not appling the brake the car will intermitatly go into a limp mode for a second. Applying the brake or swithing the shifter to tiptronic will stop the singnal & it will come out of it. If nothing is done it will only last a few seconds & the car takes off. I have had it back to the tranny shop several times becasue I was assuming that the torque converter sticking was causing the issue however the last time it was in they finaly got a code out of the ABS module 31 - 02 & 61 -01, indicating that the timing was being retarted & had nothing to do with the tranny. I replaced the ABS module just to rule it out & the same thing happens. It can be days in between events so it is so hard to trouble shoot. Like I said, it will only do when crawling through a parking lot after you first start it, warm or cold it doesn't matter. Any help anyone can give me would be appreciated, I'm at the end of my rope with this issue.
Old Jan 10, 2013 | 10:58 AM
PyroDave's Avatar
we all own cars newer than 09, try the older folks acrpss the way
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
kuzdu
Sep 10, 2015 08:42 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Allen_442
Sep 8, 2015 06:01 PM
