2012 TSX SE (Black)
Not feeling any of the filter effects.. I think you might want to work on your angles too. The wheel angles you have aren't very flattering. For example, in the first pic, it would look much better if the wheel was straight.
I just got same car in Silver moon. It's a great car.. SE keeps me from spending cash on wheels and suspension.. for now at least.
Nice man. Don't be afraid to drop a knee and get a good angle. I'd actually avoid afternoon sun if you're novice with a camera and you'll get nicer pics. Bright sun glare can wreck a photo. Also it's all about small tweaks in post. You can tweak out a high res photo in Aperture easily and improve the pic. The silver moon looks awesome in the morning and evening.
Hell I've used auto correct in Photoshop and iPhoto before and it even helps.
Good luck.
Good luck.
NYDEUCES (08-21-2012)
NYDEUCES (08-22-2012)
NYDEUCES (08-24-2012)
And I have made another experience with vinyled Fogs, most get burned when they are vinyled wet (with help from soapy water)my Fogs and some other I have done, are vinyled dry. If you use the wet method and switch the fogs before the Water has dried out, then almost every Vinyl gets burned. So maybe you only have to wait a few days before you switch on your wet vinyled Fogs?
cycdaniel
12-17-2019 10:58 AM
IndycarFaster
09-11-2015 02:52 PM
