Custom Exhaust Setup plan....
trying to get a custom setup going...how does this look?
Muffler x 2
http://ct-engineering.com/ProductLin...5/Default.aspx
resonator
http://www.magnaflow.com/02product/d...rtnumber=18135 - not sure if this is too long? should fit says outlet inlet 2.5 which is same as the muffler
muffer tips
http://www.magnaflow.com/02product/s...e=main&id=9698 - would this fit since its 2.25?
Muffler x 2
resonator
muffer tips
Muffler x 2
resonator
muffer tips
Muffler x 2
resonator
muffer tips
You got a lot of room for that resonator. If you want to change it with the mid muffler. The mid muffler is 40cm long and a diameter I think of 14cm. I have measured my exhaust, because I want to delete 2nd Cat and MidMuffler way to the T-Adapter.
Look at my Thread,maybe some good info for you on Post No.12
https://acurazine.com/forums/2g-tsx-performance-parts-modifications-299/downpipe-doesnt-fit-my-accord-843416/
https://acurazine.com/forums/showthread.php?t=843416
We all have a mid muffler instead of a resognator. Take it out. Sounds like a good plan Just make sure you put The resognator more towards The rear of The car so you wont get drone noise. And remove The secondary cat in The process. You will be a bit happier with it that way.
Im contemplating something similar, but with Megan mufflers. I just cant stand things to be half assed, and dont eant it to turn out like shit...
http://www.meganracing.com/product_d...d=390&catid=21
MidMuffler is on my drawing named with MSD, OEM Honda, lenght is 40cm (15,7"), diameter is 14cm (5,5"), the pipes after the Midmuffler are only diameter 5,5cm (2,1"), after the T-Adapter the pipes are only 4,7cm (1,8").
Maybe someone can measure the US Version if its the same.
I wannt to go 2,5" to the T-Adapter, then wait till I can afford a Sportsmuffler and connect it to my 2,5" pipe. Maybe if it drones I will get a Glasspack and weld it to the Pipes, where the MidMuffler now is.
What will removing the secondary cat do? Should I be too worried with sizing of what I'm attaching to the stock pipe or should the shop be able to make them fit?
If you start with the Downpipe, remove the mid muffler with a glasspack and end with your mufflers and tips, there is no stock pipe left.LOL
You shouldnt have to replace The whole exhaust pipe unless you want to. The only thing thats gonna boost performance is removing The second cat. The car revs a lot freely without it. A good Shop should hook it up nice. I dont know about The tips being a different size but They have machines to widen pipes.
Installing the p2r downpipe with cat delete now from throwdown and a TB spacer we'll see how freely this sucka revs afterwards. Also, I'm still so on between about exhaust and mufflers! I really do like the CTE icebox but no gains at all???! Ahhh. Guess all your getting would be the sound and stock look.
Installing the p2r downpipe with cat delete now from throwdown and a TB spacer we'll see how freely this sucka revs afterwards. Also, I'm still so on between about exhaust and mufflers! I really do like the CTE exhaust but no gains at all???! Ahhh. Guess all your getting would be the sound and stock look.
and instead of telling you to "just do it" like everyone else, i'd think carefully about this first, since this will decide if people will see your car and say, "jesus that is riced out!" or "man that sounds nice!"
i'd be very careful with what mufflers and resonator combo you choose, the tips you can worry about later since that's just the looks
Ok well I "reserved" the cte mufflers since they are backordered and also ordered the mid muffler thats on the cte exhaust. So basically making a custom cte catback. I was told the only thing different is that the y piping on the cte catback is 2inches and that they have some kind of silencer for the drone. I'll be waiting around 4 weeks
ed_423 (03-20-2012)
FlipRizzi (03-21-2012)
