Is there a speaker in the rear door?
Old Nov 24, 2013 | 09:33 AM
devitocoke's Avatar
The door looks like there is a speaker in there. If not, is there wiring to install a speaker there?
Old Nov 24, 2013 | 09:58 AM
devitocoke's Avatar
I found the answer, it is NOT prewired.
Old Nov 25, 2013 | 10:02 AM
iSeeYouTwo's Avatar
If you have the Tech Package, then there is. Otherwise, no.
Old Nov 26, 2013 | 10:28 PM
Smoked TSX's Avatar
It's Easy
When you pull off the door panels, there are black covers filled with Cotton behind the speaker grill. They can be unscrewed and thrown away. I bought rear door speakers from a TL on ebay. I ran my own wiring from the speaker and fed it through the rubber guid in the door which pops out near the seat belt. Then hide the wiring under the plastic door sill and up behind the rear seat. I tapped into the rear deck speakers so the fader would be correct.
Its a huge difference in sound quality, and loudness. Took some of the bass out of the system but over all the kids and highs improved.
Old Nov 26, 2013 | 11:18 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
I thought about doing the above, but i wonder if that could possibly damage the factory amp..
Old Nov 26, 2013 | 11:43 PM
Smoked TSX's Avatar
I did not tie into the Sub... Only the 2 6.5" in the deck, I have had it Maxed out and no issues. I know in the Tech edition there is an issue of speaker blowing but I believe they have a different amp. I am looking at adding the Center dash speaker up from too, but not sure how to wire it as of yet.
Old Nov 27, 2013 | 12:23 AM
iCrap's Avatar
How hard was it to run the wires?
Old Nov 27, 2013 | 10:15 PM
devitocoke's Avatar
I will do this, I have 3 sets of 6.5, so might as well use them.
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
obert
Oct 29, 2015 10:37 PM
Sep 4, 2015 08:03 AM
