MP3 function in new TSX
Hello
I've just bought a new Accord Tourer in the UK. Stunning car
Looking at the Acura web site, the TSX sold in the US is the same car as the TSX sold in the US. Hence my post here.
I was happy to find out that when you plug in a USB flash pen into the USB port under the centre console armrest, the audio system reads this. It reads it quickly and sounds excellent.
However, I'm unable to find out how the track order is done. You'd expect it be be done from the ID tags in the MP3 or WMA file. Failing that, then alphabetical order. However, neither work on my system and the track order is not set to random. If I upload these WMAs or MP3s to an MP3 device, the tracks order is fine. The ID tags are definitely present and correct.
Picture of tracks without numbers in their filename. The track order is completely random.
Picture of tracks with numbers at the start of the file name, for example:
01 - track 1
02 - track 2
These too are random with no obvious sort pattern.
Does anyone know how to get the tracks to sort correctly?
What about playlists? Can the audio system read them and if so, what format do they need to be in?
Thank you
01 - track 1
02 - track 2
Thank you
I ran into the same problem - the directory is not sorted at all by the audio system. Actually, it's displayed in is the order of the files in the FAT filesystem, not what anyone really wants. I've solved this by using DriveSort, link and details are in this thread: https://acurazine.com/forums/2g-tsx-2009-2014-143/sorting-audio-tracks-via-usb-connection-683979/
Enjoy!
- Mark
Enjoy!
- Mark
Now, if the TSX would just recognize ext3 ...
- Mark
i dont have the tech package, but when I use a normal usb stick for music, the songs are listed in the same order i put them in.
Hello Prox
Turns out there is a Linux util called "Fatsort". It's in the Ubuntu repositories, no doubt they'll be a package for Debian as well.
You run it on an umounted filesystem for example
filesort /dev/sdb1
I've also written a bash script which moves the MP3 or WMA files from a directory on the USB stick to the hard disk, then moves them back again in track order. Very useful if your tracks don't have track numbers in front of them, where sorting alphabetically is not useful. Let me know if you want it and I'll post it.
filesort /dev/sdb1
I've got a few older albums that don't have track numbers in front of them (ripped them myself, before I realized it was a stupid thing to do), so that script would be helpful, if you have a chance to post it.
Thanks!
- Mark
Hello
Stick these scripts in your path somewhere and make it executable. You could combine them into one script, but I've not had time.
Make sure you have write access to the temp directory if not root.
You need package python-mutagen installed for the mutagen-inspect command. This is the only command line util I've found that can read tags in both MP3 and WMA.
If the script just sits there in an endless loop, it's because one or more of your tracks lacks a track number - check them if that happens.
This forum software strips out the tab formatting, so you'll probably want to put them back in.
sortmp3
#!/bin/sh
temp_directory="/tmp/mp3"
current_directory=`pwd`
# Determine number of tracks
total_tracks=`ls *.mp3 2> /dev/null | wc -l`
echo "Total tracks: $total_tracks"
echo
# Move files to temporary directory
if [ $total_tracks -gt 0 ]; then
echo "Moving files to temporary directory..."
echo
mv *.mp3 $temp_directory
# Change to temp directory and move track backs in order of ID tag
cd $temp_directory
track_counter=1
echo "Moving files back to current directory..."
echo
while [ $total_tracks -gt 0 ]; do
for file in *.mp3 ; do
track=`mutagen-inspect "$file" | strings | grep -i trck`
track=${track#TRCK=}
track=${track%/*}
if [ $track = $track_counter ]; then
echo "${track} / ${file}"
mv "$file" "$current_directory"
fi
done
let track_counter=track_counter+1
#echo "Counter $track_counter / total_tracks $total_tracks"
done
fi
sortwma
#!/bin/sh
total_tracks=`ls *.wma 2> /dev/null | wc -l`
echo
echo
mv *.wma $temp_directory
cd $temp_directory
track_counter=1
echo
for file in *.wma ; do
track=`mutagen-inspect "$file" | strings | grep -i tracknumber`
track=${track#WM/TrackNumber=}
track=${track%/*}
fi
done
done
sortmp3
#!/bin/sh
echo
echo
cd $temp_directory
track_counter=1
echo
track=${track%/*}
fi
done
done
fi
sortwma
#!/bin/sh
echo
echo
cd $temp_directory
track_counter=1
echo
track=${track%/*}
fi
done
done
Use DriveSort, it worked great for me on a 60GB external USB drive (my old PS3 drive to be exact). It was vital to have them sorted since I had over 1200 directories and 12,000 MP3s on the drive. I could probably drive around the planet a couple of times before repeating a song. :-)
GWEEDOspeedo
01-15-2016 10:39 PM
soupi
14
11-15-2015 11:15 AM
4drviper
09-23-2015 09:00 PM
