Custom amp rack
Old Aug 31, 2014 | 08:29 AM
BlackNsexy2010's Avatar
Custom amp rack
Anyone build one of these yet? I know skathe has one.. Anyone else? Or even just mounted the amps under the rear deck.. Please post up some pics
Old Sep 25, 2014 | 11:46 PM
hokusai's Avatar
JL amp is hanging from the rear deck. I hung it with wire that i ran through the top deck
Old Sep 29, 2014 | 09:08 AM
D4nnyD's Avatar
Have any pics of your finished install? id like to see how it looks with the trim back on and wires hidden...
Also, if you jsut used wires to hold that amp in place, do u hear any vibrations from bass etc
Old Sep 30, 2014 | 09:28 PM
4evayoung's Avatar
8th Gear
Old Oct 7, 2014 | 07:41 PM
4eva..where did you get that carpet..looks likea perfect match> did you put some fans in there too?
Old Oct 7, 2014 | 07:46 PM
okay..so i made this thread because i put in an amp rack..and now im looking to tweak it..my goal was to basically get my trunk back ..i have two amps and a processor so they take up plenty of space.. i had no previous experience doing anything like this so it took me a loooonnng time lol.. lots of reading and researching and making drawings(might of gone overboard)..haha..
i acknowledge i lack expertise ..please feel free to share any thoughts comments or critiques..not only to help me but others in our growing community
so i decided to hang my 3 items from the rear deck.. each are various sizes- also.. i didn't want to drill any holes- if you look- there are some holes in the rear deck -however trying to align those with the amp can be tough.. so i decided to get slotted metal from HD and hung two of these about a few inches from the rear deck--the space was needed becasue the stock sub is there and i couldn't for the life of me take it out..
Old Oct 7, 2014 | 07:54 PM
the plan was to hang two 3 foot slotted metal across the tunk..about a foot apart to sort of form a foundation- then hang another set directly below as the bottom of my rack
- originally i used threaded rod to hang it from the rear deck
Old Oct 7, 2014 | 07:57 PM
you can see another project i have going on to the left..i have multiple projects all going on..i am relatively sure i have a minor case of add lol
Old Oct 7, 2014 | 08:00 PM
i realized quickly it was better to ditch the threaded rod.. i used some lock washers and was able to get a much better result
Old Oct 7, 2014 | 08:04 PM
you can see i got the first one installed and you can see the screws of the second one in the back
Old Oct 7, 2014 | 08:05 PM
here ive got the front and back one installed
Old Oct 7, 2014 | 08:07 PM
and finally all 4 installed.. in the middle you can see i put slotted metal across the two..i actually ended up replacing that with mdf..i dont have a pic of the whole thing setup
Old Oct 7, 2014 | 08:10 PM
i ended up having to move some of the screws around to be able to place all the equipment.. added some mdf and bolted the equipment to it.. had some grounding issues since the rack is metal and bolted to the metal of the car..you can get noise.. now..here's where i'm looking for help.. i want to get rid of the bottom row.. i want the rack to be shorter..i feel its taking up too much space but i want to feel safe about my amps being hung..any advice?
appreciate all the input..im sure its simple..just havent figured it out
Old Oct 7, 2014 | 08:11 PM
just another project i did..very easy..probably took me like 2 hours..cost about 70 bucks
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Froid
Sep 27, 2015 06:16 PM
