Aftermarket stereo Install. DIY/Guide.
#43
Not that I know of, im not sure what actually sources the compass. I dunno If its the stock deck or AC module or what. Let me kno how that metra kit works out for you
#44
yeah no problem, also got the pioneer AVH-X5600BHS. pretty stoked to get this installed and get rid of my JBL MS-8. when the ms-8 sounds good it sounds real good, so much tweaking though im tired of it. Hopefully this will alleviate that hassle.
#45
I agree. That deck you chose is solid.
#46
#47
As for the center console USB, the deck will come with a usb extension cable that is basically the same as the one that is stock in the handrest. I just popped the stock one out and routed the USB extension to the same place. It works exactly the same.
#49
Maybe if you could take a picture and post it that would be great... the rear bottom area that is.
#50
hey bro, im talking about where the vent holes are on the kit. There should be 2 places where you can put screws, one beside the vent and one below. It should be like this for both vents. My chinese kit only has a screw hole on the side of the vent.
#52
Its pretty simple as long as you read the instructions carefully. I went over it a couple times before i understood correctly.
#54
#55
yeah i got the metra kit and wiring harness and PAC for i think 90 overall after shipping, ebay is your friend when it comes to the accessories for installation, now the HU i ordered directly from a reputable site, i think newegg.com
#56
well its in, for your pioneer deck danny, what did you do for the aux and usb connection? were you able to use the existing connections? What about your XM radio can we use the stock receiver and just buy an adapter? also what adapter did you use for your antenna? the scosche adapter i got doesnt fit.
ALso what Trim did you use? mine HU didnt come with any extra trim
iamitman (03-04-2014)
#58
Can you elaborate ? I am looking forward to doing this soon.
Does PAC give you good control of the steering wheel remote buttons? Also, can Factory Mic be connected to the pioneer unit? Which pioneer unit is this?
Sorry about all the questions. But, the install looks great!
#59
The PAC works only for volume up/down, channel up/down, and mode. havent figured out if it will work for the phone operations or not.
this is the pioneer avh-x5600BHS
EDIT: not sure about the factory mic, to be honest everyone i talked to over the factory mic said they couldnt understand me very well so im using the new bluetooth mic that came with my HU
iamitman (03-05-2014)
skathe (03-04-2014)
#62
for the antenna i had to order the adapter part 'American International HO10' because the metra kit didnt come with it. FOr the Aux i just bought an aux cord and ran it to the center console, did the same with the USB.
#63
nice i want a NEX series for sure haha but with my new setup now it is quite clear to me that my speakers are my current weakest link. need to upgrade from the jl audio C3's.
#64
I am trying to not even think about speakers. My commute to work is not very long and I have put like 12.k Miles in 2 years. I just got the mountek magnetic CD mount and looks super clean. Might be all i need!
#68
Not yet. I have to manually program it. I didn't do it yet because I still gave to pick up an antenna adapter. I will have it ready by this week and will let you know. I'm going to program it for ptt, hang up and receive. However mode/vol was automatically programmed.
#69
Hey all. I have found tons of information on this forum so I decided to create a little Guide/DIY of installing an aftermarket stereo in our cars to give back to the community. I know there are several users online here that have done this install but in my research I had to get bits of information from several sources to figure everything out.
This install is not the same as installing those Chinese units that replace the top screen. This replaces the entire stock TSX radio (Non ELS/ Non tech package). As far as I know this will not work with the ELS system as the wiring is different and the stock amp does everything including EQ as well as volume control.
Please note:
Replacing the stock radio in this case retains everything with the base system. You end up using the stock amplifier and all speakers + subwoofer work. There is a world of difference in sound quality and most of all, EQ controls that are actually helpful. You can even use a HI-Pass filter to the subwoofer in the stock amplifier system. My rear deck speakers now play full range instead of just rear fill which makes everything sound so much better IMO and my stereo comes with an 8 band graphic eq which is enough for the stock system. I get clean 4V preout signals from my aftermarket deck which in turn creates a clean output from the stock amp.
Parts used:
- - Double din Stereo of your choice, I choose the pioneer avh-5500bhs as it has appmode and I can use GPS from my iphone on screen without the need for an actual NAVI type stereo.
- - Double din Frame for our tsx. I bought mine from china on aliexpress.com. Cost about $115 to Canada after all shipping+duties. It was missing two of four screw holes for the vents but still held well with just two.
- - PAC SWI-RC if you want to add steering wheel controls, which I did. You loose Bluetooth button control however. No big deal for me.
- - Metra 70-1730 Wiring Harness for 2008+ Honda accord with factory amplifier.
Install:
- - First and formost, here is a guide on how to remove your factory radio:
http://www.smartauto24.com/docs/inst...e/991-8989.pdf
- - I bought the double din frame from this link: http://www.aliexpress.com/item/2-Din...445880751.html You will have to take the vents and hazard light button from the factory frame and screw them to the aftermarket dash kit.
- - The wiring harness uses RCA’s to plug into your aftermarket deck. Two for front left and right, two for rear left and right. There is a single loose RCA harness in the metra 70-1730 kit that goes to an 8 pin connector that is used for subwoofer control from the stock harness. Since there is two subwoofer outputs (left +right) on my deck I choose one at random and I don’t think it makes a difference. Everything else is easy as there are only basic things to wire like ignition power, ground, illumination etc.
- - I routed my Bluetooth MIC to above my rear view mirror. I just ran the wire along the top headliner and through the top of the A pillar cover, to the bottom of the dash and then to my stereo. I was worried that I had to remove the A-pillar but it seems like this way worked well.
- - This is the guide for installing the PAC steering wheel adapter. I had to splice into the main stereo harness to find the two wires needed. http://www.pac-audio.com/swi/SWIAppG...er&swiOptions=
That’s it for now. I dont have much pictures as i did this in toronto while it was really cold out. If you have any questions I will try to answer when I can. Let me know if there are any broken links.
Please note:
Parts used:
Install:
Thank You
Do you know how to change out the speakers in the rear deck?
#70
There are a few posts on this forum with how to remove the deck.. it involves breaking a pin on the rear pillars that you will need to replace from the dealer.
#71
#72
for the antenna adapter, will this work (Metra 40-HD30)? http://www.bestbuy.com/site/metra-an...&skuId=9436988
#73
TxCv12 (03-18-2014)
#80
yeah there is a delay... its a problem on every deck though because of the mass storage of the drive. its a lot quicker if you use an ipod
