Window Tint Sunroof
Old Feb 1, 2010 | 02:23 AM
frog_dude's Avatar
Window Tint Sunroof
Is it worth it to tint the sunroof with ceramic tint?
Old Feb 1, 2010 | 07:57 AM
HeavyDuty's Avatar
WTH happened to my garage
I'd do it. I'm not exactly a sun-god anyway, and I bet it has a UV coating in the glass from the factory.
It probably will reduce the sun damage to the sun shade over time.
Old Feb 1, 2010 | 01:05 PM
frog_dude's Avatar
Does tinting it affect the factory tint on it?
Old Feb 1, 2010 | 11:01 PM
HeavyDuty's Avatar
It should only accentuate it. Sunroof glass is tempered like the windows, but it probably has some additional UV on it on account of it's horizontal placement.
Call a window tint shop, they should be able to tell you if there's a reason why you shouldn't. I can't think of any reason why not to.
There's some commercial tint that's completely like a mirror on the inside at night...that might be a cool effect.
Old Feb 2, 2010 | 12:28 AM
katmai's Avatar
I've always had my moonroof tinted because I like to keep the sunshade open all the time. In the summer its too hot for me with direct sunlight coming in. I've never had any problems with anything.
Old Feb 2, 2010 | 01:37 AM
ed_423's Avatar
SeeYou2Crew #2
how much do you tint your sun roof?
Old Feb 2, 2010 | 04:33 PM
katmai's Avatar
Either 15% or 35% depending on what the factory tint was. On the TSX I got 15% because the glass was already pretty light. That lets me see outside during the day but at night its mostly only lit objects. The sky ends up being pretty dark and I can't see any stars unless they're bright.
Old Feb 5, 2010 | 05:05 PM
TSX131's Avatar
I wouldn't tint it. That's what the cover is for...
Old Feb 11, 2010 | 12:37 PM
frog_dude's Avatar
Can a sunroof crack from being tinted?
Old Feb 11, 2010 | 11:20 PM
katmai's Avatar
not anymore than any other glass on your car. Why would it? Its just sticking a large sticker on it.
Old Feb 17, 2010 | 05:51 PM
frog_dude's Avatar
Isn't the factory tint spray on or in the glass? I assume putting a film on would affect the expanding and contracting of the glass?
Old May 28, 2010 | 05:59 AM
DJMcGee's Avatar
Come on, certainly you know the difference in the modulus of elasticity of automotive window glass.
Never tint a multi-paned window as it reflects the heat back between the panes. This is an issue on homes. For single pane or safety glass the same issue doesn't apply as there is no dead space between the panes or panel of glass.
Tinting a sunroof should not be an issue.
Old May 28, 2010 | 06:53 AM
08A-SPEC's Avatar
I know this sounds cheesy but you can get cling-on window tint at Walmart in 5% for $12. It goes on like regular tint with soap and water but can be removed and doesnt have the crazy glue on it. This can be easily used for a sunroof and taken off at a later time.
Old May 28, 2010 | 07:33 AM
DJMcGee's Avatar
08A-Spec. Good idea but I wouldn't use this. It will trap air bubbles and make your sunroof look nasty. Go with the good tint, you will be happier in the end.
Old May 28, 2010 | 05:20 PM
katmai's Avatar
The moonroof only costs $30 at my tint place. I think its well worth it if you like to leave it open in the summer but don't like the heat.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
