Whats the Actual Cost of dropping your TSX?
Are you trying to figure out the cheapest route or what? The question is unintentionally vague. Cheapest way to drop it would be to drive it off a cliff. Besides that kind of drop, you could do springs alone. Finding out what a local shop would charge for changing out shocks/struts would give you a labor price for that. Coilovers cost more but are a bit easier on the install especially if it is "fully assembled" like a Megan or BC Racing. Then you could always look at buying springs or coilovers used instead of new. I believe there was one single set of coilovers still for sale in the Black Market forum for the 2G TSX for $650. You might want to do some learning with the search button and what supporting vendors sell and go from there.
The following 2 users liked this post by PPower:
justnspace (12-16-2011),
nj2pa2nc (12-17-2011)
Very well said. ^
To the OP:you need to ask your self, how low would you like to go?
knowing what you want determines what the cost is. Like suggested above, get to know your springs/coilover options.
Springs are cheap. 200-300 dollar range. but only provide a set drop. and are limited to the stock shock. unless you want to spend more and get a performance shock like the Koni Yellows.
Coilovers: have the ability to damper and adjust height.
the general audience usually lean towards coilovers because of the value.
You can also save money by DIY instead of paying for a shop to install.
Yeah, it's a talent. There's definitely a lot to consider. I'd almost start with budget and figure out the best you can do with that. The budget will always get stretched anyways.
+$698.47 Megan Racing EZ Street Coilovers
+$171.99 Complete REAR CONTROL ARM CAMBER KIT
+100.00 Complete Alignment
=970.46
Springs would be cheaper but if your gonna drop it do it right the first time
=970.46
Civichbdx speaks the truth. Dont cheap out on suspension. You will regret it once your stock struts blow...The prices he quoted are pretty realistic as well. If you are not planning to install yourself, add $150-$200 for installation.
well s-techs are already low as id go, i was thinking handr but my peoples said to go with s-techs all the way
do u need moar low kowloon or is it like ride quality or something that you wanna improve?
if you want to upgrade the shock, koni yellows will do the job nicely with their ability to damper.
it just depends on what your ultimate goal is.
are you after looks or performance?
the value in coils is that you can damper all four corners and adjust the height to what ever you would like.
while, just buying springs will only allow you a set drop.
I can go into the science behind spring rates and such, if you would like.
go for it
mainly asthetics, and i dont want to decrease my ride quality is my main worry
coils i know
but im also poor
POOR
coils i know
but im also poor
POOR
Im deciding how i will drop my car as well, Ive always done 1pc Coils on all my past cars.
But the ride quality Suffers horribly! SO i was thinking STECHS
Bent = #1
Would that setup work for the wagon?
After the struts blew, the honey moon period was over. Ride quality went to crap. You could feel every bump and hair line crack in the road. Going over seams on the highway felt like you ran over something huge. I used to yell seam when taking people back up to gville, so they could brace themselves lol. I would never recommend springs unless you plan on replacing the struts soon after. I do not believe they sell any aftermarket struts for our cars yet. And when they come out, they will not be cheap. $500-600 range was what koni wanted for my old car. And at that point, you are near the price range of tein basics or megan ez.
^ freak occurrence? Alotta ppl here have been happily springing for a while ... :s I'm getting springs as a gift from someone so I'm trying to figure it out. If my struts blow in like 3 years that's fine cause in 3 years I'll have money, and ATM I'll only be putting 6k or so per year on the car
Maybe the stock struts on the tsx are more drop friendly. Good luck. The s techs do drop the car very nicely. Other brands seem to drop the rear more than the fronts .
i have s-techs and probably wouldnt consider coilovers unless they were dirt cheap or free.
IMO the drop on s-tech looks just right on 19's
i had s techs for 2 years and no issues with my shocks
btw i paid $160 to install my springs
$80 an hour
$80 an hour
Install it you old fart. I'm sure the senior citizens home has a ramp that can handle a 1" drop
WTH happened to my garage
Just getting old sucks... I had a Corvette before this and dropped it an inch for about a month, then raised it back up. It hurts having to fall into and climb out of a car any more... LOL... I look at these "kids" dropping the cars and remember when my knees were that good.
i was just busting your chops guys, didnt know it was an actual problem wed all encounter at some point o_o
Ya know you're getting old when your coilovers are called "Comfort Sport" LOL
TEIN Comfort Sport Coilover
Description
The TEIN Comfort Sport Coilover Toyota Lexus Nissan Honda is for the older car enthusiast or someone who just wants a nice comfortable cruiser and some additional grip on the road. The Comfort Sport Damper has been specifically designed for drivers seeking to improve performance, without sacrificing ride quality. Vehicle sway is reduced to increase stability during cornering and increase handling. This coilover kit features a special fluorocarbon coating to protect against corrosion. The mono tube internal design with new MSV technology allows for smooth and quiet operation. Ride height and damping force adjustable (16-levels), as well as EDFC compatible. Developed with larger wheels and tires in mind, the spring rates and damping force provides the perfect balance of performance and comfort. More information about the Tein Comfort Sport Coilover Suspension can be found on their website: http://www.tein.co.jp/e/products/comfort_sport.html
Description
Goodbye.
Description
Description
GARGHHHHHHHH!!!! I wished they made those for my 2011
i thought suspension wasnt changed between the 09-10 and the 11-12? should fit your 11 if it fits in a 10.
PS: HD and the other older guys, i feel your pain. i'd be fine dropping the TSX, but corvettes and other cars like that are a bitch for me. too many years of football, soccer, and wrestling. took a toll on my knees, and cracking 3 of my vertebrae from football also sucked. im 18, and kinda scared for when im your age lmfao. im gonna need to drive standing up =P
SeeYou2Crew #2
cycdaniel
12-17-2019 10:58 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
nuldabz
09-03-2015 05:49 PM
