underbody rust proofing?
Alternative is to get 3 or4 cans of undercoating spray and doing it yourself if you can safely do so. Ideally you need to rsise the car on jackstands and remove some of the plastic splash guards etc underneath, then apply product to sheetmetal. Don't forget to use thick grease style rustproofing inside the doors: use the drain doles underneath the doors to spray inside. I had done thay to my 2000 accord and never had rust issues up here in canada. So i did the same to my tsx. Pretty cheap, cost me less than 60$.
lanechanger
10-13-2015 10:56 AM
