Tranny Problem
Old Jun 28, 2021 | 05:00 PM
ryno92626's Avatar
Tranny Problem
I have a 2010 TSX, automatic. In fist gear, at low speeds, the RPMs spike, causing the car to lurch or leap forward. I can "
feather" it by lifting my foot just as it is happening, then it shifts into second and all good. But in traffic it's a nightmare! No codes, no check engine light. Doesn't seem to happen when it's cold. Someone said it isn't building up enough pressure inside the transmission to shift, probably due to a worn out seal, so i might as well rebuild it. It has 199k miles, but it's perfect in every other way! He recommended trying some of that seal conditioner to pour into the transmission. I was hoping someone else has experienced this and can share their fix, if there is one? Thanks!
Old Jul 5, 2021 | 08:16 AM
forward's Avatar
Fluid level? When is the last time the fluid was changed?
Old Jul 6, 2021 | 02:32 PM
ryno92626's Avatar
Fluid level is good. I thought of that, had the oil change guy check it, he said it needed replaced, so we did, and level still shows good.
Old Jul 7, 2021 | 01:32 AM
J T's Avatar
J T
Make sure they used the correct ATF fluid from Honda/Acura. Automatic trans are very picky about what fluid goes into them.
Madhattr
1G CL Problems & Fixes
Jan 2, 2016 10:17 PM
volcomst0ne24
Oct 24, 2004 11:02 PM
2007AcuraRL
Jan 25, 2003 12:24 PM
sixspdbrd
Apr 18, 2002 06:51 AM
bahreeTL
Jul 14, 2001 06:54 PM
