Tire Size
Old May 9, 2021 | 03:53 PM
fattofu's Avatar
5th Gear
Tire Size
Hi there,
I recently purchased a set of 18x8 +42 offset rims for my 09 tsx. I'm looking for a set of tires for these rims but I'm stuck between 225/45 or 245/40. Which would be the best choice without compromising the speedo too much? Also I am on stock height.
Old May 9, 2021 | 05:33 PM
the width of the two proposed tires are vastly different....
with a 225mm wide tire, it'll be stretching the tire onto the wheel...this practice is common in the stance scene as you can stretch a tire as you camber the wheels at extreme angles.
the 245mm wide tire will make the car look more aggressive. a wider tire is common in the performance scene, as a wider tire has more grip. you will be able to accelerate better, stop better, and corner better with a wider tire.
Old May 9, 2021 | 11:28 PM
evo9's Avatar
OEM size for the V6 TSX is 235/45-18 for the 18 x 8 rim
Old May 10, 2021 | 02:23 PM
BROlando's Avatar
225/45 would be totally fine on a 8" wheel.
But I would use a 245/40. It might look a *little* pinched, but honestly, most 245's will look fairly squared up.
V6 sizing shouldn't be used on a 4cyl. Your VSS isn't set up for the larger diameter rolling stock.
Old May 10, 2021 | 06:28 PM
oh shit, i didnt even catch that it was going on an 8inch wheel.
my bad
Old May 14, 2021 | 11:40 PM
forward's Avatar
https://www.rimsntires.com/specspro.jsp
Double_0 KA9
1G RL (1996-2004)
Mar 16, 2014 03:59 AM
KillerG
15
Mar 28, 2012 08:45 AM
fobstylez
May 27, 2008 09:46 PM
Triz08
May 21, 2005 03:30 PM
fahoumh
Feb 25, 2002 11:24 PM
