stuck on attempting to remove underpanel for bumper
Old Dec 12, 2009 | 09:28 PM
AC415's Avatar
i'm trying to swap out my stock fog lights for an hid conversion kit that i got so i'm reading the manual and it tells me to remove 3 clips and then pull down the underbumper. this is the part that is frustrating me as i've removed the clips but cant find a way to remove the bumper to access the bulb. any tips?
Old Dec 13, 2009 | 10:49 AM
HeavyDuty's Avatar
WTH happened to my garage
If you're doing a conversion, you'll need more room to work with than you would if you were just replacing the bulbs.
I'd just remove the cover in it's entireity, that'll give you ample room for running the wiring & ballasts, etc.
Look at all the clips and bolts holding the lower gravel guard, then there's two 8mm bolts that attach the rear upper corner of the bumper cover to the fender. With a swift tug, you can pop the cover off of the cleats underneath the headlight. If you do it this way, you can 'tilt' the cover forward using the lower bolts as a hinge.
I'm looking forward to the finished product. It rained for like two days straight here and last night I was thinking about the H11/H3 or HID driving light conversion and couldn't see for shyte last night.
Old Dec 13, 2009 | 11:10 AM
AC415's Avatar
thanks for the help. it took me a while but i figured things out last night and went on to install the new bulbs. this is how it looks like. 6000k bulbs.
Before:
After:
Old Dec 13, 2009 | 11:11 AM
AC415's Avatar
i will take full front pictures after i replace the low beams with 6000k also.
Old Dec 13, 2009 | 01:21 PM
ttk5's Avatar
Vancouver B.C.
that looks really good bro
Old Dec 13, 2009 | 02:10 PM
HeavyDuty's Avatar
I bet that's a huge difference from the halogen's.
For HID conversions, are the HID bulbs you used hotter than the stock bulbs or unshrouded vs the stock ones?
Old Dec 13, 2009 | 10:45 PM
ed_423's Avatar
SeeYou2Crew #2
looks good
cycdaniel
Dec 17, 2019 10:58 AM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
pistacio
Sep 26, 2015 09:45 AM
