Real HID driving lights? Or just talking bulbs?
WTH happened to my garage
Hey all,
I keep seeing references to HID driving/fog lamps here & there. Is there such a thing as an HID lamp assembly that would fit our cars and not what people are calling "HID looking" bulbs for the stock housings?
I'm confused.
TIA
I'm confused.
TIA
well there are of course HIDs which some people replace for their driving lights which consists of the HID bulb connected to a ballast. Since we have the OEM ballast for low beams, we can just replace it with a HID bulb.
There are of course halogen bulbs which has the HID look.
for example, i replaced my fog lights with HID fogs in which included the bulb and the ballast. for my high beams, i only replaced it with halogen with the HID look which matches my low beam HIDs so at night, its just a flood of white light
So like on yours, you did an HID conversion kit that replaces your halogen with a real HID bulb & ballast.
Got it.
But, is there such a thing like a fog/driving light assembly from another car like the MDX or RDX that is an HID fog assembly from the factory?
I believe not. I guess what you are asking that if the MDX or RDX come ready with a HID fog assembly? If that is the question, Then no, its the same halogen bulb like ours. I bought the HID fogs because it was definitely a lot brighter than a halogen but its just more like a cosmetic thing.
you may want to read this:
http://en.wikipedia.org/wiki/High-in...discharge_lamp
I believe HID's are based on lumens, measured in K's...
It also depends on the housing...
like 3000K HID. The higher the K's, the more "blue" the light will look.
It was a hot topic among 4th gen Maximas back when I had my 2003.
i also installed hid's with the bulb and ballast on my tsx had to basically take off the whole bumper but because of the fact that i got the bulb at 6k its alot more blue than the stock hid's for the headlights
Wow, I do like that, I don't really care if they aren't the same color temperature, but man, once I turned 40, my sight is getting bad quick.
yea they are alot more blue but when one of my other bulbs go out for my headlights ill probably end up getting them 6k but needless to say our HID's on our tsx are really bright my brother has a Lex GS 330 and he says my lights are better than his so yea, go figure
Looks great. Where did you order your bulbs/kit from. I wanna replace mine asap.
to tell you the truth i got the ballast from a friend for only $60 (i hustled him down from $120) but the bulbs i got them ebay.. just typed in 8k hid bulb and they were running for about 20 bucks
2005, bulb, change, changehidbulb2009tl, fla, fog, hid, hids, higher, jacksonville, light, rdx, replace, replacement, tsx
