Sorry, can't quickly find them on the wiring diagram. They may be tied to your dash dimmer. Did it get turned down?
OK, here we go. Passengers under dash fuse / relay box has a #6 (7.5a) fuse which controls the audio HVAC display, climate control unit light, etc etc etc, 5 lines of text. try that one, check it with a meter, not your eyes.
Thank you. So I am just checking to see if this fuses are blown right.
Also the dimmer wasn't the issue
Should clarify that I have the 2012 manual, don't know if they changed stuff for different years.
IF that fuse is OK, I have more work to do looking things up. Not a very clear section of the manual.
I think it's the same, ok keep me posted on what u find. Is it possible it's a bulb that's blown in the radio circuit
