LED bulbs flickering for DRL after install
Hey all. I installed 9005/HB3 LED bulbs for my DRL/high beams on ’13. They flicker for the DRL but work fine for the high beam. The manufacturer told me I will need a canbus decoder to address the flickering issue. Anyone who is using canbus decoders in their car comment on where you put them inside the engine compartment? Doesn’t seem like there’s a lot of room to place these and I don’t want to leave them dangling. Pictures of your set up would be helpful too!
i have aftermarket LED bulbs as DRL in my 12 Wagon, i bought those wire harnesses from LASFIT and using them. so far no issue and work fine
9006 9005 9012 LED Bulb Canbus Adapter Anti-Flicker Warning Canceler (lasfit.com)
can i ask what LED bulbs you are using? i was using the lasfit led bulbs with the canbus decoders from lasfit(same one in your link) as well and i still get the flickering issue. when i initially turn the car on, no issue. but once i start driving, it starts flickering.
Morimoto 2Stroke 3.0 LED Bulb is what you should have got to start with. Plug N play no add on to make the DRL works. They are the only LED bulbs for cars that uses the Hi beam as DRL. It is what I use.
TECHNICAL SPECIFICATIONS
- Intensity: 2,600lm
- DRL Intensity: 780lm (30%)
- Power: 22w
- DRL Drive Voltage: 6-9V DC
- Material: Electroplated Aluminum
- Current: 0.25-0.79A @ 12V DC
- Light Source: Osram Oslon Black Flat S 5500K (Pure White)
