LED DRL's?
Old Apr 29, 2018 | 09:57 PM
Wuzupez's Avatar
LED DRL's?
Hey guys n gals! New to the forum and also a new 08 Type S owner! Wondered if anyone has used Theretrofitsource LED high beam/DRL Bulbs? If so how do they work and fit?
https://www.theretrofitsource.com/le...ect_restrict=1
Old Apr 30, 2018 | 10:29 AM
guitarplayer16's Avatar
They're amazing and bright. My friend has the morimoto DRL LEDs from them, they're bit on the pricy side though, as you can see 120$. You can expect them to be VERY bright and last a long time though.
Some people buy bulbs that cost like 20$ for the pair from china and then complain about it not being bright enough or failing.
You sir, seem like you're willing to do it right the first time and spend that dough. I like that.
I will say though that there are bulbs that are cheaper and offer similar brightness.
The bulbs themself are plug and play.
You'll need a DRL harness to accompany the bulbs. I like the iJDMToy harness, it does the job simple and well. Cheap too.
https://store.ijdmtoy.com/LED-Daytim...rl-decoder.htm
Option R3.
Old Apr 30, 2018 | 10:58 AM
truonghthe's Avatar
What bulb you recommend? I am curious as I will use a set extra LED high power got laying around that since I sold the Lexus.
Old Apr 30, 2018 | 11:06 AM
do it.
high beam on our Type S doesn't use this bulb so you don't have to worry about that.
Old Apr 30, 2018 | 11:12 AM
Wuzupez's Avatar
I'm guessing the retrofitsource will offer this harness that's needed as well as the LED bulbs?
sockr1
Sep 30, 2017 09:14 PM
cacheflowe
Sep 13, 2016 07:35 AM
jray906
May 21, 2013 09:59 PM
apdspider
Dec 2, 2012 03:44 AM
citidelx
Mar 31, 2010 12:07 AM
