Intermittent A/C problems
I've been having Air conditioning problems on my 2010 TSX. When the A/C works it's cold, no problems. When it's not working it will just cut out randomly. I bought a new relay switch and a magnetic clutch fuse (7.5) and swapped both of them yesterday. A/C worked on the way to the store, didn't on the way home. I'm fresh out of ideas any idea?
I would suggest checking the pressure in both the high and low pressure lines first. You can buy an A/C service tool set or take it to a shop, as it's not something you can do with non-specific tools.
What I did on another car when I knew my A/C was not working correctly was take it to Firestone, have them perform the system test, then repair it myself after finding out what was wrong. I also have the service tools and a vacuum pump (also necessary to evacuate the system before refilling), so you may just want to pay a shop to do it all at once.
It's possible the condenser is clogged or partially restricted, too. While you may be able t visually inspect the exterior of the condenser, it's nearly impossible to know if everything is flowing properly inside the condenser. Aftermarket condensers are less than $100, so probably worth replacing while the system is evacuated.
Had the same symptoms with my 09 TSX...compressor failure. When the compressor fails, it spits crap throughout the system and thus you'll be replacing all the components or risk the garbage causing another failure in the near future. I believe mine was ~$1500 at my go-to mechanic. Good luck.
Pr0fug01
09-13-2013 02:24 AM
scottthomp
1G TSX Problems & Fixes
06-11-2010 04:38 PM
