A/C Not Working
Old Apr 19, 2019 | 03:49 PM
airlyss's Avatar
A/C Not Working
Hi everyone,
I bought my new-to-me '09 RDX in November right before winter started, so wasn't able to test the A/C when inspecting. Turns out it blows hot air.
I read a few other threads that pointed to replacing the engine bay relay, so I did that today hoping it would solve it, but unfortunately no change.
When I push the A/C button, I can hear the clutch engage, but the air temp stays the same. Anything I can diagnose DIY, or should I just bring it in?
Old Apr 20, 2019 | 05:35 PM
CSmoney28's Avatar
CSmoney28
The compressor in our vehicle is bad, I had to replace mine.
Old Apr 23, 2019 | 01:17 PM
hingram's Avatar
7th Gear
My air sometimes works. I would say most of the time it works. But I don't hear the clutch engage. When it engages, it works. I replaced the freon last year and it worked more often. There is no rhyme or reason. I can get in it in the morning and it isn't working. I can hit the button a nunch of times and it comes on.
Old Apr 24, 2019 | 06:15 AM
hues10's Avatar
First option is to check refrigerant pressures. GF 2010 CRV was intermittently blowing warm. Thought it was going to be compressor clutch relay. Turned out to be low refrigerant. One half can, and it works super cold.
Old Apr 25, 2019 | 08:45 AM
Boxster98's Avatar
Check pressure 1st
My RDX was low on R134a. I had a crack in high pressure hose (rubber). After hose was replaced, and put under Vacuum, then refilled again. it worked fine
Old Apr 25, 2019 | 12:39 PM
CSmoney28's Avatar
CSmoney28
Replace refrigerant it acts as the lubrications for the system.
Then check the hoses for cracks or leaks if needed replace them.
Then check the compressor to see if the clutch is spinning when you have the ac on, if not it’s stuck at this point and you need to replace the compressor.
Old May 5, 2019 | 06:28 AM
hingram's Avatar
7th Gear
My mechanic said I needed a new clutch. When the clutch was engaged, I added refrigerant. That seemed to fix it. A good test is to bypass the relay (youtube it) and see if the clutch engages.
Old May 7, 2019 | 12:09 AM
CSmoney28's Avatar
CSmoney28
I guess your clutch froze
Old May 7, 2019 | 07:15 AM
hingram's Avatar
7th Gear
If your system is below the freon threshold, the clutch won't engage. I probably have a leak somewhere.
Old May 8, 2019 | 12:12 AM
CSmoney28's Avatar
CSmoney28
Check your hoses and fitting like I said you might have a cracked hose. Also the Freon is a lubricant not just a refrigerant so I could be low and cause the clutch not to move. But remember the rdx is known to have a bad compressor, clutch, and ac system. They had a recall and issued an extended warranty for these very reasons.
sseiyah
1/2G MDX (2001-2013)
May 15, 2018 12:37 AM
PhilWithers
2G CL Problems & Fixes
Mar 11, 2009 04:31 PM
jpooncanada
Apr 9, 2007 07:55 PM
tjmedford
Oct 4, 2006 11:03 AM
