Installing Decklid Spoiler with 3M Tape Troubles
I recently bought a decklid spoiler paint matched for my TSX.
I installed it a couple days ago for the third time after having problems with the edges the first time and rain the second. This time I made sure to do all of the proper things to install after doing lots of research to make sure I got it right. I prepped the spoiler, put on the automotive super-strength 3M double sided tape on the edges of the spoiler, washed and cleaned the trunk surface with alcohol, dried the surface, test fitted, masked the edges, peeled back the edges of tape and put on some adhesive sealant on the spoiler, installed and heated the tape, pressed it down securely in all places for several minutes, and then held the spoiler down with tape overnight in the garage.
All of the spoiler seems to be extremely secure today but for some reason the sides that are coming off already and I'm wondering if there's anything I can do to make the sides adhere without taking off the spoiler again. The rest of the spoiler is really well cured. The surface is still pretty clean since the car is in the garage. This is my third time doing this and I will be giving up after this, since I do not want to drill the spoiler.
Thanks in advance.
Thanks in advance.
justnspace (07-28-2020)
This part is lifting up. I made sure when installing that this rounded part was adhered first and well before the edge to the right in this picture. Unfortunately, it just doesn’t want to stick at the rounded part.
EuroRspec (07-28-2020)
What would your recommend I do now?
I suppose I could still try that without taking the spoiler off. I have a blow dryer that can get really hot. I don’t exactly want to use a heat gun, but how long would I need to heat it for on a heat gun?
I think part of the issue is the spoiler isn't a perfect match to the curvature of the trunk. If it's plastic, I would get the whole spoiler really hot and tape/clamp the edges down overnight.
dealornodeal (07-28-2020)
It is ABS plastic. How long do you recommend I heat it for and roughly how long on each part?
Also do you think that it might be a problem that I put the tape right on the edge? Should I have put the tape in some from the edge? Just wondering, thanks.
Null and proud of it
I've tried heat on things like this before, it may work, but I think your downfall here isn't the adhesive, it's the pulling away force caused by the spoilers shape, the curve isn't exactly matching possibly.
dealornodeal (07-29-2020)
Thanks for the help guys, I really appreciate it. With all things considered, the spoiler looks really good and is cured really well, except for those curvature points that aren’t adhered. So I’m just going to cut my losses here since and invest my time elsewhere, since I don’t think anymore time I put into it is really going to benefit it long term. I put some RTV silicone adhesive sealant near that rounded spot when I installed it, so the spoiler should hold well for awhile. If it comes off or I face more problems, I’ll just take off the spoiler and consider a lesson learned, that I should just pay a hundred extra or two to get an OEM spoiler and possibly get it installed by a professional. Thanks again for the help guys.
Midnight Mystery (07-29-2020)
I don't think the adhesive promoter would help. The root of the problem is the actual spoiler and how it's manufactured.
Ok. Now after I’ve installed or is that if I reinstall?
Are you planning on reinstalling? That would be your best bet, but I would try to do it now.
Also, how did you apply the tape on the spoiler? You really don't need much. Just two long strips running lengthwise down the spoiler. Most OEM applications do not go all the way to the edge, they stop 1/8th inch from the end. Also, to manage expectations, it may never look absolutely perfect. Even OEM spoilers that are glued on have slight separation on the edges.
Midnight Mystery (07-31-2020)
I could heat up the edges again with a blow dryer, but every attempt I’ve made with it previously hasn’t actually helped. The tape always seems to fail on the rounded part, whether I heat it up before installing, when installing, or after. I could go out and buy a heat gun, but I’d rather not drop anymore $.
Understood.
I think you're probably just fighting the geometry of the spoiler not being shaped exactly to the curvature of the trunk lid. The only way I'd see it going flush is with a threaded bolt, which isn't a good idea, IMO.
Jimmy The Saint
1G TSX Photograph Gallery
11-06-2010 09:22 PM
