Hit a curb
Old Jun 13, 2010 | 02:46 AM
espdollar's Avatar
Hit a curb
so crapy luck i took a green too fast and went into a slide. i was going 20-30 mph and the front right rim hit the curb straight on and broke a piece off. On the way home it was creaking and grinding so i drove slowly. what kind of damage may i be looking at? axel damage? thanks for the help
Old Jun 13, 2010 | 03:14 AM
ttk5's Avatar
Vancouver B.C.
wow, I've honestly never seen anything like this before. You may have damaged your suspension; how did your steering feel on the way home?
On the flip side you now have a reason to get some after market wheels
Old Jun 13, 2010 | 05:09 AM
1islandparadise's Avatar
Damn....that's a huge chunk of wheel missing. I've acutally hit a curb just as hard before in my old Maxima. I had to replace the lower control arm (I think that's what its called), shock (used this as a reason to buy some aftermarket springs), and had to get the front end aligned. The car had a very bad vibration after that, that never went away. Also one of my CV axles popped out about 8K miles later. I had to let her go after that.....
Old Jun 13, 2010 | 08:10 AM
coffeefingers's Avatar
DANG. You went into a SLIDE at 20-30 MPG? On a left handed turn? On city streets?
That wheel is a goner. Not even the guy who fixed the road rash on my wheels is gonna be able to fix your rim. LOL.
Better take it into your dealer.
Old Jun 13, 2010 | 10:04 AM
rastaracer's Avatar
RastaRacer
damn, thats messed up. hope it doesnt cost much to get fixed, you should probably tey to get aftermarket wheels now since the cost of the oem acura rim & tire is probably not cheap.
Old Jun 13, 2010 | 04:09 PM
espdollar's Avatar
some more pics. when i drove home i did hear a couple big pops when i hit a bump or two. when i let go of the wheel it seemed to veer to the right. looking at it in the day light it looks bent.
Old Jun 13, 2010 | 04:57 PM
Gabe15's Avatar
I agree. It doesnt look right. Take it in.
Old Jun 13, 2010 | 06:40 PM
patcracks's Avatar
why dont you take it off at least and put the spare on...thats some hit tho damn lol
Old Jun 13, 2010 | 06:54 PM
espdollar's Avatar
lol sorry i meant to say i was turning left and went into a skid
Old Jun 13, 2010 | 07:07 PM
espdollar's Avatar
idk i wasnt planning too since im not driving it till my apt on wednesday at acura 2 miles down the road to see how much they could fix it.
Old Jun 13, 2010 | 08:19 PM
SSFTSX's Avatar
you should search ebay or craigslist and buy the wheel.
Old Jun 13, 2010 | 08:30 PM
lightjak_tsx's Avatar
keep us posted...
Old Jun 13, 2010 | 10:16 PM
ed_423's Avatar
SeeYou2Crew #2
holy crap..thats a big chunk missing man. good luck!
Old Jun 13, 2010 | 10:33 PM
TSteezyX's Avatar
and that's how I met my friend TE-37.
edit: I don't follow your story. What did you slide on? Or did the car just understeer wide into the curb?
Old Jun 13, 2010 | 10:56 PM
espdollar's Avatar
Old Jun 13, 2010 | 11:45 PM
ed_423's Avatar
SeeYou2Crew #2
looks like someone took a bite on your wheels lol
i'd say..check if anything else is screwd up, if its just the rims, get a cheap used one. even if it has some curb, at least its better than what u got now lol
unless of course, u got the $$ for new set of aftermarkets
Old Jun 14, 2010 | 01:54 AM
bastircar's Avatar
sry about ur wheel, ul have to change it, even if some one tell u that he fix that rime, it wont be safe...
search on E-bay i think ul find just 1 rime at a good price.
or u can use this bad luck to buy a new set of rimes (sry evil)
to one another...
Old Jun 14, 2010 | 02:11 AM
09TSXTech's Avatar
Sorry about the wheels. Take it to the dealer to make sure there's no suspension damages.
In the meantime, a quick check at craiglist in Miami shows a set of 4 17" TL rims which should fit your car for $180 but they may go pretty fast at this price.
http://miami.craigslist.org/mdc/pts/1787999416.html
Old Jun 14, 2010 | 02:15 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Old Jun 14, 2010 | 04:32 AM
bastircar's Avatar
oh... forgot, (no edit tool) for any damage you should consider 2 times the impact and check the suspension and the flight angle... posible threats but in my history with honda (i have european accord same as tsx) u realy have to work hard the car for a damage...
to one another...
Old Jun 21, 2010 | 05:49 PM
espdollar's Avatar
Update - went to the dealer they first wanted to replace the rim and do an alignment to see if it was bent. after replacing the rim alignment was off and you can even see that the wheel bent back in the well. so they want to replace the lower arm, knuckle, hub, clip, ring and bearing which brings the repair to a few dollars short of $2000. they said that after replacing those parts and the alignment was still off the sub frame of the car could be bent which would tack another $1400 on the repair.
i'm pretty young and insurance is outrageously high for a 21 yr old in miami *$5k annually* so i'm gonna sell some stock to pay for the repair out of pocket. i know the repair is pretty expensive but i'm not sure i should take it somewhere else since the car has 13k and i was planning on getting another 6-8 years off of it. what do you guys think?
Old Jun 21, 2010 | 05:53 PM
SOCAL BRO!!!'s Avatar
got brohoes?
They didn't say anything about the CV joint?
Old Jun 21, 2010 | 07:33 PM
baltimorecaesar's Avatar
Best case scenario, you only bent a tie rod and need a new rim/tire. Worse case, you have a bent frame etc.
Old Jun 21, 2010 | 11:46 PM
09TSXTech's Avatar
Take it to a reputable auto body shop. The dealer may end up replacing everything and still not getting it right. Remember, a dealer can change oem parts, but body work and frame work they farm out to auto collision body shop. I agree with so-cal, you CV joint may be toasted, they will throw the alignment way off.
Old Jun 21, 2010 | 11:52 PM
09TSXTech's Avatar
The first car I owned was a 1981 Pontiac T1000 which is basically a Chevette. I got into an accident and got all the body work done, the shop told me I need the frame straighten out as they can't get my alignment straight. This is a rwd car, so I took it to my trusted mechanic, and it turned to be a bented spindle, problem solved. Long story short, the CV joint should definitely be looked at before any frame repair.
Old Jun 22, 2010 | 03:41 PM
SSFTSX's Avatar
$5k is too high price. even $2K for new car. try to trade it with another used 2009 TSX with similar price with dealer. Most likely you will pay couple of grand extra but you will get CPO
Old Jun 22, 2010 | 08:11 PM
espdollar's Avatar
Got the car back. Heres a list of the parts used.
Old Jun 22, 2010 | 08:42 PM
patcracks's Avatar
bro you got owned..drive slow homie!
Old Jun 22, 2010 | 09:19 PM
espdollar's Avatar
lol yeah i will be scared to drive this thing for a while
Old Jun 22, 2010 | 09:44 PM
defconskylude's Avatar
OMG
$508 for one 17x7 OEM rim
Old Jun 22, 2010 | 09:55 PM
got brohoes?
Idk how they are looked at in the car word.. since they are the only way to make a fwd car pretty much.. but in the world of trucks they are to be babied and if all that was broken, I would listen carefully to the cv joints for popping.. or look for a tear in the boot.
Old Jun 30, 2010 | 03:37 PM
espdollar's Avatar
yeah cv is on its way out, makes clicking noises when i turn sharply. i'll get it fixed when it breaks :/
4drviper
Apr 23, 2025 07:13 PM
08KBP_VA
Oct 22, 2019 01:55 PM
calrow
May 3, 2017 10:21 PM
lanechanger
Oct 13, 2015 10:56 AM
