HID problem!!
Old Jul 26, 2011 | 02:29 AM
npathak's Avatar
Exclamation HID problem!!
So i was driving after i changed my stocks to 6000k and my friends noticed that the left hid is "flickering" and just being weird.
so tonight about 5 mins ago, i parked my car and whipped out my camera.
i noticed that its a leveling issue not much of a flickering.
it seems like i maybe had put them back on wrong, or maybe something internal (headlights).
has this happened to anyone else?
- i've noticed the cut off issue ever since i got my car back from the shop (accident) maybe i should run it by and have them fix everything.
but is there anything i can do?
Old Jul 26, 2011 | 04:06 AM
Jonnie5's Avatar
if ur talking about the left being slightly lower, then that is normal, its so that ur left headlight won't shine into oncoming traffic, mine is stock, looks like that too, normal
Old Jul 26, 2011 | 05:57 AM
DJMcGee's Avatar
Not sure about the flickering but your headlights do not appear to be aligned correctly
Old Jul 26, 2011 | 06:34 AM
civichbdx's Avatar
X2
Old Jul 26, 2011 | 06:41 AM
its rayden's Avatar
there should be adjustment knobs somewhere on the headlight assembly to adjust the projectors. be careful not to turn them beyond their limit as you can damage it. if you're not confident doing it yourself, bring it to the dealer for adjustment.
Old Jul 26, 2011 | 10:15 AM
defconskylude's Avatar
maybe your hid bulb is upside down or loose
Old Jul 26, 2011 | 11:07 AM
npathak's Avatar
i made sure that they werent upside down because the bulb and its outlet can only fit if they are properly inserted.
is that the turning plate that is outside of the hid bulb? the round plate on the back of the housing?
Old Jul 26, 2011 | 12:07 PM
pinatubo's Avatar
Have you ever get pulled over by patrol officer?
I remember there is a member got pulled over 'cuz of his HID.
This might be the case.
Old Jul 26, 2011 | 12:25 PM
npathak's Avatar
Naw. Cops in diamond bar don't care what so ever for HIDs. Everyone (EVERYONE!) has them here. I've seen multiple people with 10000k cruising.
Old Jul 27, 2011 | 01:15 AM
npathak's Avatar
Talking HID leveling fixed!
DUDE I LOVE YOU! no homo...
so i thought the knob was the huge black round cover of the HID bulb....
BUT! i was stupid and then saw what rayden was talking about. these small bolt-looking knob that has teeth at the end.
clockwise is lowering it
counter-clockwise is heightening it
pictures of the fix...
Old Jul 27, 2011 | 01:20 AM
ed_423's Avatar
SeeYou2Crew #2
there you go, looks good now
Old Jul 27, 2011 | 01:23 AM
KillerG's Avatar
Op is too busy to care
nice fix dude, btw what does npathak stand for?
Old Jul 27, 2011 | 01:39 AM
npathak's Avatar
Thanks! npathak is my name Neil Pathak. (its pronounced Pathick) most people get it wrong :/
Old Jul 27, 2011 | 02:50 AM
Acura_Dude's Avatar
David_Dude
I actually read your last name right.
Oh btw for the comment posted earlier about a member who was pulled over for his HIDs. His were STOCK. No aftermarket bulbs whatsoever.
And I do agree about how everyone gets away with the HID craziness. There's a white accord sedan (94-97) driving around with violet bulbs. I'm not sure if they're HIDs (12000K) or just regular bulbs coated in a purple film. I freakin HATE that car, especially catching them coming my direction. 6000K should be the limit. Ideally 5000K.
Old Jul 27, 2011 | 06:55 AM
its rayden's Avatar
they still look slightly off. the "step" you see from each headlight shoud be at the same height, like so..
Code:
       ______    ______
______/  _______/
and if you back up your car a little more from the wall, they will eventually merge into a single step.
Code:
              _______________
_____________/
yours look like:
Code:
                     ______
       ______ ______/
______/
Old Jul 27, 2011 | 09:27 AM
pinatubo's Avatar
Looks much better, m8
Old Jul 27, 2011 | 11:58 AM
npathak's Avatar
Code:
       ______    ______
______/  _______/
Code:
              _______________
_____________/
yours look like:
Code:
                     ______
       ______ ______/
______/
yea i couldnt really figure that one out, do you kno how i could level them back again? maybe redo the bolts. or even redo them so they are somewhat pointing toward the middle?
Old Jul 27, 2011 | 03:38 PM
ed_423's Avatar
SeeYou2Crew #2
if nothing goes well, you can always take it back to the dealer and tell them to re-level it should be included in warranty...if not, should be free (since all they do is twist the thing)
Old Jul 28, 2011 | 12:11 AM
PyroDave's Avatar
ray are you sure about that? if i recall correctly the drivers side projector is cutoff lower, making it look uneven but that is the correct way so that the drivers on the opposing side are not blinded
Old Jul 28, 2011 | 11:13 AM
are you getting 6k turn signals?
id really like to see that combo 6k low and 6k turns
Old Jul 28, 2011 | 11:19 AM
ressling's Avatar
Originally Posted by djmcgee
not sure about the flickering but your headlights do not appear to be aligned correctly
+1
Old Jul 28, 2011 | 03:33 PM
npathak's Avatar
yea im waiting for vled get some in stock. and i just installed 6000k fogs so everything should match.
i somewhat kinda wanna get 3000k fogs instead. idk still debating.
Old Jul 28, 2011 | 03:35 PM
i already have vled v2 switch backs 6k and 3k fogs with stock 4300k low beams.
Old Jul 28, 2011 | 04:26 PM
KillerG's Avatar
so its like mad different colors up there huh?
Old Jul 29, 2011 | 08:45 AM
mrstak's Avatar
7# werC 2uoYeeS
LOL if defcon gets new switchbacks, I'm buying his old ones and I'm gonna end up having that same combination. Gonna get 3k HID fogs, leave my low beams as stock and have his switchbacks.
I may decide to change up lows to 5k or 6k though...we shall see. Every car here has stock fogs...my buddy got 2500k bulbs for his fogs and it stands out differently from other cars. Plus, I plan on going snowboarding a lot so I'm going to need more functional colored fogs over form.
Old Jul 29, 2011 | 10:39 AM
yea man it looks weird
i already got my new turn signals. just need to find time to install them and take pics
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
