-Grille info--
Old Oct 7, 2015 | 01:23 PM
alexbenz's Avatar
-Grille info--
Was this just a 3 slat grille that was painted and had a acura emblem installed?
Attached Thumbnails -Grille info---9a86cfd9-ace5-4841-bcc8-e1eda449aac1_zpschxgqup5-1.jpg
Old Oct 7, 2015 | 01:51 PM
HondoGermany's Avatar
Looks like Euro Preface grille with Acura Emblem
Old Oct 7, 2015 | 02:11 PM
robpp's Avatar
Graphite Ghost
search cu2dan
Old Oct 7, 2015 | 02:25 PM
kostantinos's Avatar
old style euro grille either painted or wrapped and acura logo put on
Old Oct 7, 2015 | 02:53 PM
xtcnrice's Avatar
VTEC just kicked in, yo!
That's jeroplex's car. PM him for details. IIRC, it's a replica pre-facelift Accord Euro grille, and he cut the H out and molded an RL-sized A emblem in place. Not sure if the bars are painted/wrapped/dipped/etc.
Old Oct 7, 2015 | 02:54 PM
xtcnrice's Avatar
Yeah CU2 Dan was the first to do it I think, and he has a writeup somewhere on here. His car had so many goodies...
Old Oct 8, 2015 | 09:13 AM
xtcnrice's Avatar
Originally Posted by jeroplex
Old Oct 8, 2015 | 11:52 AM
alexbenz's Avatar
http://www.ebay.com/itm/121261868609?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i can't just use this and add a Acura emblem to it?
Old Oct 8, 2015 | 12:03 PM
Keiji's TSX's Avatar
Looks good!
Old Oct 8, 2015 | 02:15 PM
Originally Posted by alexbenz
Not sure, but I think the white car on this Picture is a Facelift bumper and grille, not 09/10. The grille itself maybe is 09/10
Old Oct 8, 2015 | 02:56 PM
xtcnrice's Avatar
Correct!
Old Oct 8, 2015 | 04:34 PM
cu2wagon's Avatar
Originally Posted by xtcnrice
Correct!
And to complete the answer, no. You cannot just install an Acura emblem in place of the Honda emblem. They are different shapes. That is why others have gone the cut & fit route.
Old Oct 9, 2015 | 04:04 AM
boki_cu2's Avatar
so i got a Honda genuine grill if anyone interested to buy one from Aussie land haha.
got myself a modulo one
Old Oct 9, 2015 | 08:34 AM
xtcnrice's Avatar
Damn boki going modulo front?!
Old Oct 9, 2015 | 08:50 AM
opboarding's Avatar
Hello World
Facelift grille? How many American dollars for it?
Old Oct 9, 2015 | 09:00 AM
boki_cu2's Avatar
Sort of....still hunting for parts
Aus is hard to get this stuff as our lovely honda discontinued all coulor parts and then even uf you can get it comes in primer, while you guys have acess to it all.
Grille will go on current bar for now
Old Oct 9, 2015 | 09:01 AM
boki_cu2's Avatar
I sent pm
Old Oct 9, 2015 | 01:45 PM
I dont know if is that difficult to change the H to A. If you dremel (cut) the A from the inside circle, then fix the inner circle and put the Acura Emblem inside. This maybe a good way, if the Acura Emblem fits well in the circle. I have a white piece of Metal behind the H, might help if the A has not the perfect size to fit. Maybe this is a easier way to convert, but not sure, just a idea!
Here aPic of my Front in work
Old Oct 10, 2015 | 11:14 AM
jeroplex's Avatar
yes thats my car....it a pre face lift replica that the "H" was cut out and used a RL logo/housing and molded to where the "H" was. Also the chrome was all painted with black not wrapped.
Old Oct 27, 2015 | 12:38 PM
alexbenz's Avatar
so this ebay one sells the grille without a emblem....will a acura emblem fit onto it?
Acura TSX 09 10 Polished Chrome JDM Style Front Bumper Hood Grille w O Emblem | eBay
Old Oct 27, 2015 | 12:42 PM
xtcnrice's Avatar
Probably not. You can either cut and put the A in like jeroplex did, or get a slightly smaller A emblem and stick it onto some sort of backing plate that has the same shape as the part of the grille where the H should be.
Old Oct 27, 2015 | 02:08 PM
alexbenz's Avatar
is the H emblem smaller than the acura logo? Would the A from the rsx be smaller? It'll be easier to do that, I can make a backing plate or find one and do that than cut and mold
Old Oct 27, 2015 | 02:26 PM
xtcnrice's Avatar
This I don't know; haven't done the conversion myself. I think evo9 user has done this with his grille; the backing plate method. You can try PMing him for details.
Old Nov 24, 2015 | 11:41 AM
Aaronkoenig's Avatar
I'll be working on this over the weekend. I'll update as I make progress. My thought is to use the flat center piece that comes with the new grille as a backing and drill two small holes and attach a rear emblem using adhesive... Any thoughts on that? I got a trunk emblem off an RL and as far as I know it's the same size as the front emblem on the tsx...
Old Nov 24, 2015 | 12:01 PM
The oem honda grille needs to be remolded or a plate needs to be installed to cover the H area as that area is not flat, but deep.
If you look at the replica grille, the area where the h belongs is flat, so you can add a A logo there easily.
If you look on istagram for member gorgeousgriiiis, I believe that's what she did.
Old Nov 24, 2015 | 12:12 PM
I ordered a replica... I'll post pics this weekend if it works out!
Old Nov 24, 2015 | 12:20 PM
cu2wagon's Avatar
I think what everyone is saying is that the "H" emblem and mounting plate are a different shape than the "A" emblem.
If you just stick the "A" in place in the "H" spot, you'll see the molding lines of the "H" behind the "A" badge. You'll need to do something to cover that up.
Or not, I suppose. You'll see when you have parts in hand. Post up what you end up doing because I'm sure there are plenty of folks interested in the results and steps taken.
Good luck!
Old Nov 24, 2015 | 12:25 PM
Good luck!
yes you are correct, for the oem this is the case, but not for the replica
Old Nov 24, 2015 | 12:29 PM
cu2wagon's Avatar
Oh, good point Kostantinos! I didn't look that closely at the rep grille.
Well, hopefully it'll go easier then!
I still wonder how the "trapezoid" backing with a "squircle" badge will look though...
Old Nov 24, 2015 | 12:42 PM
some pics for you
I sold her boyfriend the headlights and he wanted to buy my grille too but it was to pricey, so he went with rep from ebay
Attached Thumbnails -Grille info---screenshot_2015-11-24-13-34-36.png   -Grille info---screenshot_2015-11-24-13-36-15.png
Old Dec 1, 2015 | 04:08 PM
So this turned into a process... The grille I received ended up having the H in the middle (unlike the image the seller provided). I ended up buying bondo and filling the space between the H. After a few layers and endless sanding, I ended up with a flat surface. Of course, while sanding the bondo wildly, I scuffed up the black and silver parts of the grille. I ended up taking the whole thing apart and priming all the pieces. I painted the base satin black, the trim metallic silver, and the center slats matte black. I used some 3m to attach the A the center. Came out great!
Old Dec 2, 2015 | 08:28 AM
xtcnrice's Avatar
Great job! Sorry to hear you messed up the silver pieces, but the end result looks great
Old Dec 2, 2015 | 10:04 AM
ulrblitzer's Avatar
That doesn't look half bad. I'd go this route too if I didn't just paint my OEM beak.
Old Dec 4, 2015 | 12:34 PM
alexbenz's Avatar
i would report that ebay seller....Ad's misleading. I'm going to get that grille but i have a idea for it
Old Dec 5, 2015 | 09:13 PM
loner's Avatar
Got the same grille off eBay and used an emblem off an 07-09 MDX. Emblem looks maybe a hair too big for my own tastes, but is just fine.
ExcelerateRep
Feb 4, 2016 04:23 PM
HairyMonkey019
Oct 19, 2015 09:58 PM
docboy
Oct 10, 2015 09:14 PM
6MTSSR
Oct 4, 2015 04:04 PM
