Does this floor jack work?
Old Jun 7, 2014 | 10:36 PM
adversary's Avatar
I got it at Harbor Freight. It is 3 tons, which is fine.
The problem is that it's not low-profile. Does this look right?
The jack fits under the car with just an inch from the bottom of the bumper.
Also, the jacking point on the floor jack has an open cup. Am I supposed to buy a block of wood to put over it?
http://www.harborfreight.com/3-ton-s...ump-68048.html
I am really hoping I didn't buy the wrong one.
Attached Thumbnails Does this floor jack work?-jack-1.jpg   Does this floor jack work?-jack-2.jpg
Old Jun 7, 2014 | 11:05 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
that's fine and it will work....
Remember to use jack stands before you get under the car... especially with harbor frieight jacks.
Old Jun 8, 2014 | 01:03 AM
adversary's Avatar
what do i fill in the jack cup? a block of wood?
Old Jun 8, 2014 | 03:16 AM
adversary's Avatar
i think im going to buy some 2x4's tomorrow so my car will have more clearance when i drive my front wheels over them
Old Jun 8, 2014 | 04:31 AM
adversary's Avatar
seems like ill just fit a hockey puck into the jack cup
Old Jun 8, 2014 | 09:08 AM
iCrap's Avatar
just put the cup onto the car's jacking point..
Old Jun 8, 2014 | 11:24 AM
xtcnrice's Avatar
VTEC just kicked in, yo!
As iCrap said, it's fine to use the cup directly with the jacking point. I've done this several times already; the underbody has not crumpled by any means.
I don't have a low-profile jack either. I use 2 layers of 2x8s to get enough clearance. However, my car does not go up the 2 layers all at once. Let your car go up one layer first, then another layer, to avoid scraping if she's low.
I use something similar to this, but with only 2 levels, minus the gradient edges because I'm lazy to saw them.
Old Jun 8, 2014 | 11:28 AM
usdmJON's Avatar
Whoa at these questions
Im sorry if this causes offense but just making sure you dont get hurt... you HAVE used a jack before correct? You have jack stands too I hope?
I ask because that is a pretty standard looking jack right there. Not sure why youd have questions. Most jacks have a cup sort of attachment. This allows the lift point to be more secure in case it slips.
You're good to go with what you have... assuming you have jack stands.
You dont need any 2x4s from what I can see.
Just position the jack like you did in the first picture and make sure that raised section of the frame sits inside the Cup of the jack. Once you get the car up put the car on secure stands and leave the jack for extra support if not in the way.
Never leave the car on a Jack alone and break your lugs BEFORE lifting... oh and make sure your ebrake is on and youve got blocks if you need them. Be safe, not sorry.
P.s. There are also videos on youtube that would help.
Old Jun 8, 2014 | 11:29 AM
usdmJON's Avatar
xtcnrice thats a crazy ramp! lol lol
My front lip hangs too low for my low profile jack but I just use one 2x4 for each wheel so Im not lugging around a huge ramp like that.
With the front wheels on 2x4s I still have to lift my front lip bu hand to get the low profile jack underneath.
Old Jun 8, 2014 | 11:50 AM
adversary's Avatar
im literally a beginner. i am worried that if i use just the cup, the car will somehow slide off the contact point as what i have read in some other people's posts about their car collapsing. i am just trying to take some precautionary measures. the jack is literally bending the liner of the car, so i think getting some 2x4's would help.
i am trying to jack the car from the front. isnt the front jack point of the car that circular bump that sort of sticks out? it just looks really small and i guess id feel more comfortable if i had some sort of rubber thing making contact with the car's steel frame.
yes i have jack stands, im planning on putting 2 jack stands on each side. i also will use chocks.
Old Jun 8, 2014 | 11:57 AM
xtcnrice's Avatar
lol! Yeah that's not mine I have something way more basic than that; simply 2 2x8s stacked on top of each other without the gradients and the giant block at the end lol. Oh and mine aren't all glued together either haha
Old Jun 8, 2014 | 12:05 PM
usdmJON's Avatar
You are correct. The spot in the first picture right above the cup is the jack point. I believe there is even an arrow pointing to it.
I have a harbor freight jack with the cup end as well. It is not the same jack but the jack plate is similar.
I jack my ILX from the same spot in the picture you posted. However if you can see you are bending something then I would stop and wait for someone local to help maybe. I you are using that jack point nothing should be bending though.
Good luck OP.
https://acurazine.com/forums/1g-tsx-2004-2008-124/tsx-jack-up-lift-points-pics-765630/
http://www.tsxclub.com/forums/1st-ge...locations.html Read this second one carefully. The circled areas he was told NOT to use.
Old Jun 8, 2014 | 12:20 PM
adversary's Avatar
yea, you can't really see it but if you look at the first pic again, the top part of the jack is touching the liner. that's why i feel that i should get some 2x4's or 2x8's
Old Jun 9, 2014 | 04:35 PM
Simba91102's Avatar
Old Guy
What's with you guys jacking the car up from the front? The proper jack points are on the sides, front and rear. The OE jack has a slot that the jack points on the sides drop into. Too bad the OP bought that big axle jack. They also have a nice aluminum 1.5 ton model that is pretty low profile and pretty fast; I'm not a HB fan, but it is a nice jack. I use a small piece of 2x4 with a slot cut into it that the raised lip on the car slips into, and it sits on the cup of the jack.
Old Jun 9, 2014 | 05:30 PM
adversary's Avatar
my friend used his 1.5 ton aluminum low profile and it broke. that's why i opted for the 3 ton. i think if i just roll my car onto some 2x4's, it'll be fine.
Old Jun 9, 2014 | 05:36 PM
adversary's Avatar
what do you guys think of my jack adapter that i will use for the front jacking point of the car?
ive been searching the internet and people say a hockey puck works well. i got myself a hockey puck and wrapped it around with dycem material - an extremely non-slip material. fits pretty well in the jack cup.
Old Jun 9, 2014 | 06:03 PM
EzeE1o's Avatar
i lift the front by jacking at the front cross member. there's an arrow pointing to the spot molded in the plastic.
Old Jun 9, 2014 | 06:05 PM
robpp's Avatar
Graphite Ghost
the front and rear are jacking points in the service manual as well as the owners manual; sides ARE ONLY SHOWN USED with a lift or jack stands
if I lift it from the side then how do I place jack stands to hold the front off the ground
please explain
Old Jun 9, 2014 | 06:14 PM
EzeE1o's Avatar
Hmm, I have the blue1.5 ton one. How did your friend's break?
Old Jun 9, 2014 | 06:18 PM
adversary's Avatar
we added a block of wood on the jack cup. just when we were about to have enough clearance to place jack stands on the sides of teh car, the jack just slowly descended by itself, dropping the car back down.
Old Jun 9, 2014 | 06:19 PM
usdmJON's Avatar
It's okay he's old.
Perfectly fine jacking it from the front OP at the jack you bought it perfect as well. You are better off with a 3 ton than a 1.5 any day of the week.
As for the liner, you are fine bending it a little. I literally have to lift my front lip up like an inch and rest it on the jack just to slide the jack under the lift point.
You're fine getting some 2x4s if it makes you feel better. Same for the puck.
Old Jun 9, 2014 | 06:20 PM
robpp's Avatar
Graphite Ghost
im old too but not a farking idiot/ just the FACTS MA'AM/
then the jack is broken or the piece of wood collapsed.
dont use wood. just use the FARKING JACK like the rest of us.
i even posted a service manual picture so you get the point.
Old Jun 9, 2014 | 07:40 PM
rawger's Avatar
Are we sure this isn't Soupi's 2nd account?
Old Jun 9, 2014 | 08:01 PM
iCrap's Avatar
lololololo soupi.
also the amount of stupid in this thread is astounding.
Old Jun 9, 2014 | 09:47 PM
xtcnrice's Avatar
I jack the car up from the front/back so that I can place jack stands on the sides. Otherwise, my jack would be in the way and I wouldn't be able to put it down on stands.
Old Jun 9, 2014 | 09:48 PM
xtcnrice's Avatar
please explain
this
Old Jun 10, 2014 | 07:07 AM
ceb's Avatar
ceb
C'mon guys, here is the proper way to do it
If that is too extreme, then this might be smarter
or not....
Old Jun 10, 2014 | 08:55 AM
xtcnrice's Avatar
That is hilarious ceb!
Old Jun 10, 2014 | 09:35 AM
robpp's Avatar
Graphite Ghost
this/
Old Jun 10, 2014 | 03:54 PM
Simba91102's Avatar
Old Guy
this
I stand corrected. Since the jack that is included with the car lifts the car from the side, it never occurred to me to lift it from the front or the back. I still won't/wouldn't by the way (never been a fan of the one jack method), but I see now why it's evidently popular. As far as jack stand placement goes, once the car is up, there are numerous places where a stand can be placed.
Old Jun 10, 2014 | 03:59 PM
the_tl_man09's Avatar
^1 one time i had a jack fail while i was up under the car without jack stands. not a fun experience
Old Jun 10, 2014 | 05:05 PM
usdmJON's Avatar
You want to use jack stands period like I said earlier.
Even if you dont get under neath... do you really want to have a wheel or two off the car and the jack fail...
Old Jun 10, 2014 | 10:56 PM
iCrap's Avatar
Always use jack stands..
Old Jun 10, 2014 | 10:59 PM
adversary's Avatar
thanks in advance.
i am gonna jack the car up from the front with my non-slip hockey puck adapter, put two stacked 2x8's under each of the wheels, and then put 2 jack stands on each side of the car as well. might seem overkill but i'd rather go batshit insane than have my head squashed.
Old Jun 10, 2014 | 11:49 PM
xtcnrice's Avatar
It's a good thing you're even alive
Old Jun 10, 2014 | 11:57 PM
rawger's Avatar
You know when ceb's posting pictures to get his point across he has had enough.
Old Jun 10, 2014 | 11:58 PM
rawger's Avatar
Fack. Where you hurt at all or did you escape?
Old Jun 11, 2014 | 05:20 AM
ceb's Avatar
ceb
thanks in advance.
Don't forget the blocks at the wheels.
Old Jun 11, 2014 | 07:50 AM
Yea i actually still hurt from it, it happened about a year and a half ago. It broke my collar bone, punctured my lung, and broke broke 10 of my ribs. It's a good thing my buddy was there he was the one that got me out from under the car because i was sure pinned down. Ribs still hurt from that mess but im just thankful to see another day ya digg
Old Jun 11, 2014 | 08:56 AM
jonnys_honda's Avatar
thanks in advance.
My tsx is so low, I have to REMOVE the cup adapter on a low-pro jack, in order to get under the jack point. Maybe someday I'll save $$ for air-ride.
That's insane. Hope you continue to recover!
