Do you guys have the headlight set to Auto all times?
Hi,
Quick question... i was driving other day and came to this thought...
I know day time running light will always be on when the engine is on.
But, when i put them on automatic, will going back and forth between DTRL to HID will hurt them in a long run?
And is there a way for HID light to turn off as soon as the engine is off as well? I don't like the HID to be on for 15 seconds after the engine is off... but want to leave it on auto...
I would want it set as auto because I sometimes don't turn on the HID at all at night... but don't want to wear out the HID when I leave and it stays on..
thanks
thanks
Don't use auto if you care about longevity on your ballasts.
You can set the auto off timer on your mid I believe. I have mine set to auto and have driven 100,000 miles over 4 years. No issues. Haven't had to change the hid bulbs or ballasts yet.
I as other have posted turn on my hid's when it's foggy out.
VLED is coming out with an LED harness that will be able to fully utilize low diktats and high voltage for high beams. I'll be getting some when they release them this summer.
Received 7,772 Likes
Yup. Auto all the time unless I need to manually override the position on or off.
The auto setting has made me lazy and now I feel like a common pauper when I drive a vehicle that requires me to *manually* turn the lights on.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Azine Jabroni
Nothing about it is stupid. It should probably be mandatory, seeing how many people on the roads nowadays forget their headlights. It's way too high.
Auto lights aren't stupid. People who don't know how to use them are.
komplexZ (03-27-2016)
ROTAREDOM
I forget how you adjust the sensitivity...
In other news.. leaving it in Auto mode won't hurt anything. OEM's usually guarantee over 1million cycles.
ILX owner.
I never use Auto. Never have probably never will. Im just in the habit of turning them on when I need them.
I do leave fogs on whenever my headlights are one which I probably shouldnt do. But I like the amber glow i see when driving close to a wall or uphill so I leave them on when headlights are on.
I'll be upgrading to some decent fogs soon at which point Ill probably start keeping them off so they last longer.
I don't use auto only because of my concern about the ballasts. I had my lights set to "min" for several weeks, but they were still turning on in wooded areas and under overpasses. If I had halogens or LEDs I would, but I have found the auto is too sensitive for me in normal use.
ILX owner.
Your eyes are naturally drawn to the brightest light - one reason we can't help but look at oncoming headlights - even momentarily.
If you turn your fogs off, then your eyes will be drawn further up the road. Turn your fogs on and your eyes will be drawn closer to the front of the car.
This makes perfect sense in fog. In heavy fog you hould be driving much slower and you'll want to see directly in front of your and the sides of the road to avoid obstacles - but during clear weather with faster speeds you'll want to see farther down the road so that your speed doesn't outrun your reaction time.
While we often talk about those "junky foglights", very few of us realize that they are working as designed and that there is science behind that design.
Everyday I'm rofling
I used auto for the first month or so. Then I got annoyed how they would come on all the time when going under overpasses and in parking garages etc. Now I'm all manual. I'm the boss.
Personally I don't use auto with my Tl... I don't think it will hurt the parts because they are oem.... and keep In mind for those who doesn't like it.. it's a safety feature you can always turn it off .. I'm more concerned with my fogs burning out than my headlights.
ROTAREDOM
Yours would look even better cause you have the Tritons.
You need to get the tritons! They are amazing. Plus you can transfer those to any car you end up buying in the future.
ROTAREDOM
They still need resistors right? I have my current ones already wired up. Problem is, I can't remove the headlights without ruining the wiring I did.. I didn't leave enough length to pull the headlight out and remove the LED ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
I want the tritons, and I thought about being able to use them on any other vehicle too, but it would look silly if you didn't have headlights that weren't already cleared out (amber removed).
Also, I think maybe I saw that VLED is going to make a plugnplay version? Already has resistors and right adapter.That would be awesome.
https://acurazine.com/forums/photogr.../#post15303570
ROTAREDOM
Ohhhhhhhhhh yeah I remember now, cool! yeah I should do that haha
Anyone selling for cheap?
Graphite Ghost
i had tritons in my lights PNP resistors are built in. and there is room behind the light to mount them to the fender....resistor box still gets hot/
Graphite Ghost
Or, you know, just adjust your sensitivity so you don't have your headlights go on under ever overpass.
![what](https://acurazine.com/forums/images/smilies/what.gif)
thats not very nice.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
i called the inanimate AUTO FEATURE STUPID, I didnt direct my comments at a person.
you must be of the Millennial gen, or maybe just surrounded by it, so you need a NANNY to tell you when to put your lights on.
a nanny when to put your brakes on.
i dont feel like being banned today so i will stop her but I guess you need a nanny to remind you to do everything.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
i rather be the master of ALL OF MY DOMAIN including WHEN to put the lights on.
ROTAREDOM
^^ Rob is the type of guy who makes his OWN sandwich.
robpp (03-28-2016)
Azine Jabroni
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/610x300/udi7snz_c40c1683c7c849b05745bc086f7e543f88adc6d1.png)
I stand by what I said. The auto lights are adjustable.
VTEC just kicked in, yo!
They're adjustable, but not good enough. I've set it to the least sensitive setting and tunnels/woods will still trigger unwanted on/offs.
I had no idea the wear-and-tear from on/offs is actually a non-negligible thing. Stopped using auto today
I will have had my TSX for 8 years this May. I have always set the lights to "Auto". They are set to med sensitivity. They come on when in tunnels, parking garages, etc. So far no issues with my HID's.
xtcnrice (03-29-2016)
ROTAREDOM
lol I said that OEM's generally guarantee 1million cycles (sometimes even more). Trust me when I say we go through many many many tests to ensure the lifespan of the parts. Leaving it on Auto is completely fine. It was designed to handle everyday situations.
Back to auto they go! But I do manually flick the stalk off/on when it misbehaves, regardless of component lifespan. It's sometimes annoying to see my map switch from white bg to black bg (and vice versa).
ROTAREDOM
Correct. You are actually ruining your long range night vision.
Turn off your fogs, you heathens.
I headlights are always fully ON. I come from a background of driving tiny cars. The TSX is by far, the largest car that I've ever bought. Huge. Ship-like, even, as compared to my previous/other cars.
It helps to be a little more visible. So...by habit...lights always fully on as soon as I get in the car.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
I may be fat but I'm slow
I call BS. 75k on my 2011, 65k on my 2004, 25k on my wife's RDX, and 105k on my S2000 (granted, no auto headlights).
Never had a single headlight problem. It's a non-issue.
The only time I take my car off of Auto is when I need to turn the lights on for rain/snow and it's too bright for them to come on on their own.
i thought it would ruin the HID whenever I switch off to auto...
glad that OEM lasts that long... I would not turn on the auto hid if TSX had led or hid day running light...
Op
You need a bicycle since you don't want to put miles on your car or use up the headlights.
My exotic cars get more use than your tsx
Live a little
https://acurazine.com/forums/second-...-go-up-929076/
Live a little
xtcnrice (03-31-2016)
Im accustomed to turning them on and off myself I actually get annoyed when the go on automatically... I hear auto can give trouble in cold weather if your battery is close to dying
