CU2 Accord factory shift light??
So I remember seeing a youtube video when I was first looking at 2G TSX of a Euro CU2 that had a stock-looking shift light built into the tachometer (where the AT indicators usually are).
Google is bringing up nothing.
I looked on youtube again. Although I can't find the original video I'm thinking of (I recall it being more steady and not having the red gauges), this video shows what I'm talking about:
Thoughts? Can this be had?
EDIT: found a couple more videos showing what I'm talking about
Also, I wish our MID showed the symobls instead of text for each function (e.g., picture of a car --> gas pump instead of "distance to empty" or whatever it shows in the USA MID).
Well this is actually the first time i"ve actually heard of it. It does look like it will work with a 6-speed. My only concern would be if there is an extra computer or wiring that can be adapted to the TSX.
What are your thought?
Next questions would be part #'s and if if it's just a simple plug and play or if additional electrical work is needed.
ROTAREDOM
I didn't know the euro version had that indicator. You won't find that in north American cu2s. I'm gunna say this won't be possible for you, even if you bought a euro cluster, your ecu would have no way of relaying the information to that shift light since that function is not available here.
If I may suggest, just get a HUD. It's much cooler and you can set when you want your shift indicator to come on.
I will admit the shifting lights are cool. My bro's IS RPM gauge turns orange when its time to shift and then red as you approach red line. But honestly I don't think it's worth putting extra money out for a feature like that. After you drive some more you can shift gears correctly by just looking at your speed. I only look at my RPM gauge if I'm being an idiot and want to rev high for no reason.
ROTAREDOM
^ I looked into getting lights that slowly changed color when approaching red line... too much money/wiring/rice outcome
BLKOUT714 (09-07-2012)
And no, it's not because I don't know when to shift. Just thought it would be a cool, subtle add-on.
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
