Bump steer 14 TSX
Bump steer 14 TSX
Hey guys does anyone have bump steer? I feel as if my steering wheel pulls left and right going over uneven roads, alignment tire rotations and pressure at all good. Now the wife drives it so I don't know if she hit a pot hole before. I'm thinking it may be a tie rod or lower ball joint. Car has 16k miles.
When was it last aligned? What type of tires? Is it lowered or does it have any suspension modification?
I have a lot of bump steer with my 2011. I figured it was due to me lowering it but who knows at this point. It seems worse with my aftermarket wheels/tires than it does with my oems. I haven't been able to pinpoint the cause yet and just have dealt with it.
last aligned in Feb last year and problem has existed since, acura said all suspensions parts are in good state.
hey no mods Bone stock and it was aligned last year after the pothole, funny thing is on smooth roads it handles great its certain uneven roads it never use to do that.
I'd have the alignment checked again. A year is a long time...and they may have either gotten it wrong last year, or they overlooked a bent component. Bent components aren't always plainly visible.
If your alignment print out shows a large lack of caster on one side, for example....it may be a bent part as a result of the pothole.
Caster issues can result from an arm bending backward and can cause wandering over uneven surfaces.
I do not have any excessive bump steer from my lowered wagon with stock tires, blizzaks, or 18" Conti DW's. Your alignment may be off.
Can caster be adjusted on our cars or its only toe in and out?
hondas2kcr
Mar 11, 2016 08:22 AM
