Black White theme K24
MOST of the time, the factory strut bar is fine and you wont see big improvements going to an aftermarket one.
I cant find the dimensions to the OEM bar, but i wont give up!
additionally, your car naturally oversteers from the factory.
to get the car be more neutral; a larger rear sway bar would help a lot MORE than a strut bar could ever do.
then if you would like to even out the car even MORE, you could upgrade to a larger front sway bar. not to be confused for the strut bar.
I would try swapping that intake manifold cover with the one for the k24 Si.
They use the same intake manifold...its should fit, check to see if the part numbers are the same for the bolts.
^yea, I saw how you're decking your engine bay out so I was like "the si cover is wayyy cooler"...so I figured you'd be interested
ok so the bolts won't be exactly the same...the si has these nice rounded bolts on top (as you can tell from a visual comparison)..but the im part numbers ( 17100-R40-A00) are the same so it should work...don't see why they wouldn't since same part number means same threading locations, etc.
^make sure you order with all the screws in stuff...i just placed my order. $50 shipped
justnspace (08-13-2012)
ed_423 (08-13-2012)
ROTAREDOM
yay painted engine bays
sorry, no Pics underneath,
look at Joes Post No.27, the two screws are on a different place than at mine. At my cover they are on the outside on Joe´s car they are more on the inner side. Is this what you mean. Maybe there are two different (manifold??)parts
SUPRMN84
10-07-2015 09:46 PM
justin.w13.walker
09-22-2015 02:21 PM
