Battery Replacement
Battery Replacement
My battery needed a few jumps this past winter, the last of which it couldn't even unlock the door after less than a week's rest.
I was just about to replace it when spring finally arrives and it has been good for the past week. Were any of you in a similar situation?
- Would you wait until the following winter to replace?
- I see a ~$80 Interstate 500 CCA battery at Costo, would this be a good option?
I purchased the exact same battery 3 weeks ago due to the battery showing signs of weakness in colder weather. I am in southern Texas therefore do not see this type of weather often but did not want to deal with the battery failing when I was within a time constraint. Before changing, make sure you have your radio ID number as you will be prompted for this post installing the new battery. My radio number was not in my glove box therefore I had to call Acura who quickly provided.
My oem 4 cyl battery lasted 2012-2017.
Jan 2017 i put in costco battery 500cca. Its running perfectly fine still.
Sudden changes in temperature, both cold and hot, will cause a battery to fail. I guess it's the shock. Sometimes you can charge it and be fine, sometimes not. I prefer to replace it asap so as not to be stranded. The Optima is a fine choice and Interstates are good too. My 4 cyl 2014 shows signs of slowing down so I'll be replacing it soon probably on the cheap side with what ever Auto Zone or Walmart sells.
So if your battery were choking this winter but it's now perfectly fine now that the polar vortex has passed, you'd hold off on a change till next winter right (Except TexasTSX, thx for the tip about the radio #!)?
Get the Optima Red made for the V6... just need the top bracket
read here
https://acurazine.com/forums/2g-tsx-...attery-952200/
read here
In that very link you will see where I recommend a much bettery option for battery.
Doc Holliday
18
09-27-2005 03:12 PM
StonedCL
08-05-2005 02:50 PM
speedjunkie
08-04-2003 08:11 AM
shaolin
07-20-2003 11:28 PM
