2G TSX Chat, Chit, and General Info Thread
Old 08-06-2014, 11:03 AM
  #14921
VR1
Itz JDM y0!
VR1's Avatar
UC is more abrasive then M205 but less abrasive then M105. M105 I think would be too harsh for a newbie like me to use at first try. I heard UC is hard to screw up aswell. From meguiars: "Since UC is derived directly from M105 and uses essentially the same abrasive set, it can and will cut very quickly." SwirlX is also more abrasive then M205 iirc.
I found a 7424XP for $120. Think I'll get that and M105, UC, M205 and swirlx and experiment. Swirlx can be done by hand, so what pads are recommended for M105/M205 & UC? I think practice with swirlx and UC then move up to M105 if necessary.
Old 08-06-2014, 11:07 AM
  #14922
TSX AMG Type //M i-VVT
iCrap's Avatar
Just get the harbor freight DA. it's like $50. Order an orange CCS pad also.
I found UC to be totally useless though but you could just try and see if it works for you
Old 08-06-2014, 11:21 AM
  #14923
VR1
Itz JDM y0!
VR1's Avatar
One thing about the 7424xp which is the main reason I'm looking at it is I heard if you press to hard or go over an uneven surface it'll automatically stop so you don't burn through your paint.
How hard is it to do this polishing stuff anyway? Is it easy for a newbie to screw up?
Old 08-06-2014, 11:27 AM
  #14924
iCrap's Avatar
Nah it's really easy. Its pretty hard to burn your paint with a DA.
Old 08-06-2014, 11:36 AM
  #14925
VR1
Itz JDM y0!
VR1's Avatar
So I should buy this http://t.harborfreight.com/6-in-vari...her-69924.html instead of the 7424xp? After I use m105/m205/UC what should I finish with?
Old 08-06-2014, 12:02 PM
  #14926
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
What if he turns it to max speed and leaves it on the same spot for 5 minutes straight? You have to account for all the details. You never know what he'll do.
Old 08-06-2014, 12:18 PM
  #14927
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Use the speed 1 before the max speed, and make sure you don't leave the DA in one spot for a long period of time like op was alluding to.
VR1 I don't think you'll need to spend on all of those products. Just pick 2 of them and 2-3 different pads (1 milder pad for applying wax, not for cutting) and you'll be good. I recommend M105 over UC. Like iCrap, I've tried UC and it hasn't done much for me. I'm gonna try it out again over the weekend... but so far I'm not sold on it. M205 has been working wonders for me, and is more or less your "finishing" compound. Just apply wax/sealant after and you should be good. The plus about getting a DA is, you can get a very mild waxing pad and apply wax this way instead of by hand.
I've heard mixed reviews about the habour freight DA... but it's cheap, so you get what you pay for. I have the Griot's Garage 6" and it's pretty awesome.
Old 08-06-2014, 12:36 PM
  #14928
iCrap's Avatar
Yeah get that. Use any finishing compound... whatever megs has is fine.
Well, if somebody is THAT stupid then they kinda shouldn't be polishing their car
Old 08-06-2014, 12:54 PM
  #14929
VR1
Itz JDM y0!
VR1's Avatar
So M105 works well? Is it ok for a newbie to use or is it more difficult then say M205 or UC? After M105 should I use M205 or go directly to Wax?
Old 08-06-2014, 01:30 PM
  #14930
damaged442's Avatar
Start with least aggressive and see what that does. If the results are not what you want, step it up.
I have not yet played with 105/205 combo, but if you have them both, I see no need to have UC and Swirl X in the mix. The results I have seen on others vehicles from just 105/205 seem pretty damn good.
I would recommend Lake Country 5.5" pads. Get a few orange and a few white. If you want to apply LSP using the DA, pick up a blue/red/gold pad with no cut.
Old 08-06-2014, 01:36 PM
  #14931
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
Sandpaper
80 grit
Works 60% of the time everytime
The following 2 users liked this post by ssjoeboe9:
MC MiYoung3269 (08-06-2014), VR1 (08-06-2014)
Old 08-06-2014, 02:27 PM
  #14932
iCrap's Avatar
50% of the time, it works every time.
CFed my grille and LED'ed my fogs. I really hate having a front plate.
Old 08-06-2014, 03:06 PM
  #14933
opboarding's Avatar
Shove it in the lower grille part of the bumper. A++ highly recommend.
iCrap (08-06-2014)
Old 08-06-2014, 03:08 PM
  #14934
opboarding's Avatar
Originally Posted by ssjoeboe9
Sandpaper
80 grit
I wrote out something veryyy similiar to this yesterday saying to use 80 grit. I wrote it all out it and then didn't post it, as I do pretty often.
I think we are mind linked.
ssjoeboe9 (08-06-2014)
Old 08-06-2014, 03:10 PM
  #14935
iCrap's Avatar
Yea but what did you do about the holes in the bumper?
Old 08-06-2014, 03:11 PM
  #14936
xtcnrice's Avatar
shove it in the lower grille part of the bumper. A++ highly recommend.
+1
Old 08-06-2014, 03:18 PM
  #14937
opboarding's Avatar
Use the bumper plugs. They don't look great but aren't terrible. Check out MCyoung's car for good pictures of them. I got lucky and didn't have any holes drilled for my plate. But now I have a giant toe hitch dent there from some drunk chick.
The following 2 users liked this post by opboarding:
iCrap (08-06-2014), xtcnrice (08-06-2014)
Old 08-06-2014, 03:22 PM
  #14938
iCrap's Avatar
Oh, then i'll find some plugs for that
Old 08-06-2014, 03:39 PM
  #14939
Graphite Ghost
robpp's Avatar
yeah thats smart. stop the airflow that cools the engine/
Old 08-06-2014, 04:15 PM
  #14940
opboarding's Avatar
I usually just go hoodless for max airflow.
Half of the plate when stock dipped down into the lower grille and I just moved it all the way down. I still have the upper grille + V6 fog vents for airflow which should be enough. I'm sure there is a small measurable difference under certain conditions but is it enough to make a difference in real world driving? I don't know. I haven't had any problems in the past few years in Texas heat.
iCrap (08-06-2014), xtcnrice (08-07-2014)
Old 08-06-2014, 06:54 PM
  #14941
ROTAREDOM
ssjoeboe9's Avatar
I just put my plate in my front windshield.. dunno how strict they are about it here.
Luckily CEB doesn't troll around these parts or else I'm sure he would have plenty to say about this.
MC MiYoung3269 (08-07-2014), xtcnrice (08-06-2014)
Old 08-06-2014, 10:39 PM
  #14942
iCrap's Avatar
Yeah I highly, highly doubt that putting the plate on the lower grille will have any affect on the temps...
Some cars even have electronic seals that close the lower grilles at speed to increase MPG.
I found these btw
http://www.bumperplugs.com/index.php...&product_id=70
Is this what you were referring to?
Old 08-06-2014, 11:01 PM
  #14943
opboarding's Avatar
Yeah but those are way too expensive. I think I remember seeing someone in the 3G section who bought a ton of these and was selling for like $5/set. Also post in the facebook CU2 group since this is something that people probably have laying around.
Old 08-06-2014, 11:12 PM
  #14944
iCrap's Avatar
Yea $30 or whatever seems like way too much... I'll pay like $10 at most. Ill keep searching. posted also in that group
Old 08-06-2014, 11:26 PM
  #14945
Goodbye.
TSXy Luster's Avatar
Old 08-07-2014, 01:06 AM
  #14946
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
I found these btw
http://www.ebay.com/itm/OEM-Honda-License-Plate-Caps-Bumper-Plugs-Bolt-Hole-Covers-Black-/251586788835?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AS2000&hash=item3a93bdbde3&vxp=mtr
Old 08-07-2014, 04:13 AM
  #14947
VR1
Itz JDM y0!
VR1's Avatar
Is M105 a lot harder to use then UC or M205? I heard M205 isn't that difficult since it has a longer buffing time, but I heard M105 will become hard to remove if you leave it on there for too long. I think I'll order some M105/M205 and Wax. I'll order some LC Orange & Yellow pads (I'll use yellow if Orange on M105 isn't aggressive enough), and white for M205. Then Yellow or Red for LSP Wax.
Also, if I order pads for the 7424/Harbor Freight polisher, can I just put them on directly or do I need to buy a new backing plate aswell for the new pads?
Old 08-07-2014, 09:25 AM
  #14948
Graphite Ghost
robpp's Avatar
Only v6 has fog vents and open 100% lower grille holes.
But your giving advice to a I 4 owner.
So its not apples to apples. Perhaps in your v6 model its fine.......but not everyone had a v6.
I suspect there is a reason the 6 has open fog vents and open grille.....COOLING. so the 4 has much less lower air THEN you want to block 90% of that.
Keep telling yourself it will be fine.
I'm out.
Old 08-07-2014, 10:55 AM
  #14949
xtcnrice's Avatar
If you get 5.5" pads, you should get a 5" BP. Bigger pad, bigger BP. Vice versa. Of course, the BP should not be bigger than the pad; I think this one should be fairly obvious.
I got 5.5" pads so I got myself a 5" BP. Reason I went with 5.5" is that people don't recommend the large pads because they're harder to control, and it'll be harder to detail finer detail areas (like the scoop/groove under your door handles for example, the 6"+ pads won't fit under there).
I'm not sure what kind of BP comes with the PC or harbour freight DA, check that as well in case you buy something you don't actually need.
Old 08-07-2014, 11:40 PM
  #14950
iCrap's Avatar
Just mounted da fuck out of a curb
dont drive pissed off.
Old 08-07-2014, 11:51 PM
  #14951
Old 08-07-2014, 11:55 PM
  #14952
xtcnrice's Avatar
Old 08-07-2014, 11:57 PM
  #14953
iCrap's Avatar
Old 08-07-2014, 11:58 PM
  #14954
xtcnrice's Avatar
minor damages?
Old 08-08-2014, 12:00 AM
  #14955
iCrap's Avatar
Not totally sure... it's dark so I can't tell but I don't see anything obvious. Saw a bit of new curb rash. Gotta wait till the morning.
And then my passengers smudged the fuck out of my doors. Fuck people -_-
Anyway, I just got an Autogeek coupon. What stuff do you suggest for washing? Wash mit and some MF? I have some megs gold soap already.
Old 08-08-2014, 12:15 AM
  #14956
iCrap's Avatar
Why are they all like 40 - 50 bucks?
http://www.autogeek.net/sponwasmit.html
Old 08-08-2014, 12:21 AM
  #14957
xtcnrice's Avatar
I got my washmitt off amazon:
http://www.amazon.com/Meguiars-X3002-Microfiber-Wash-Mitt/dp/B000RXKR6M/ref=sr_1_1?ie=UTF8&qid=1407475048&sr=8-1&keywords=meguiar%27s+wash+mitt http://www.amazon.com/Meguiars-X3002-Microfiber-Wash-Mitt/dp/B000RXKR6M/ref=sr_1_1?ie=UTF8&qid=1407475048&sr=8-1&keywords=meguiar%27s+wash+mitt
Get a grit guard, wash mitt, MFTs, and apply wax with your DA on a light pad. Wax won't just keep the shine... it should also protect your paint a bit. I hate driving others around too... -_-
I'm about 1/3 way done polishing the car now... what a difference lol
Hopefully your car is fine. Curb your wheels a bit more to motivate you into some new wheels
Old 08-08-2014, 12:30 AM
  #14958
urbanstereo's Avatar
i personally use unicorn mane.
MC MiYoung3269 (08-08-2014)
Old 08-08-2014, 12:34 AM
  #14959
iCrap's Avatar
Originally Posted by xtcnrice
I got my washmitt off amazon: http://www.amazon.com/Meguiars-X3002...%27s+wash+mitt
Alright so I have all that except for the mitt and the grit guard so i'll get those two. thanks.
Yeah polishing makes a HUGE difference.
And yeah i need some new wheels lol.
I guess amazon is still cheaper than autogeek so ill get it on there.
lmao
Alright so got a grit gaurd, mitt, Megs drying towel and a phone case (had to bring the price up because the mitt is an " add on item") lol for $40 shipped. not bad.
Old 08-08-2014, 12:45 AM
  #14960
xtcnrice's Avatar
If you don't know it already, review the 2 bucket system if you wanna ensure you don't add scratches back onto your paint. Then you should be good to go
iCrap (08-08-2014)
Quick Reply: 2G TSX Chat, Chit, and General Info Thread
