2G TSX Chat, Chit, and General Info Thread
Old 11-11-2013 | 06:57 PM
  #10121
iCrap's Avatar
TSX AMG Type //M i-VVT
Yeah i know, but the dealer will probably blame the issue on my "modification"
Old 11-11-2013 | 08:29 PM
  #10122
MC MiYoung3269's Avatar
Originally Posted by iSeeYouTwo
What kind of air suspension is cwins on?
Custom setup on Megan coilover shocks
Old 11-12-2013 | 04:59 PM
  #10123
ATLBuckeye's Avatar
Originally Posted by iCrap
So i am now car-less for a week..... Has anybody else had problems with the VTC actuator and grinding on startup, and also parasitic draw killing the battery?
Its the VTC Actuator. I had this. It only happened 1 in every 50 starts. I took it into the stealership and told them to look at it. Took them 1 day to get parts and another to install. Free of charge on powertrain warrenty.
Check your alternator on your battery issue. Have a auto parts store check it for free to rule it out.
Old 11-12-2013 | 05:12 PM
  #10124
Because Texas Crew at the Big ass Texas meet acouple years ago.
Old 11-12-2013 | 05:15 PM
  #10125
iCrap's Avatar
The issue is that they said it has to make the noise while it's at the dealer. How did you prove it? Or did it do it when you took it in?
Old 11-12-2013 | 08:57 PM
  #10126
ATLBuckeye's Avatar
I didnt prove it or I got lucky. Ill credit my mehanic at Acura Carland here in atlanta. I think they just helped me out.
He "claimed" he heard it but i think he was hooking me up. Anyway you can try a different dealer? Or just be straight with them. Its warrenty work so Acura will reimburse the dealership so its no cost to them.
Old 11-12-2013 | 09:06 PM
  #10127
iCrap's Avatar
Yeah my dealer in an ass. Every rep tells me that acura requires them to reproduce the problem at the dealership.
Old 11-12-2013 | 09:16 PM
  #10128
ATLBuckeye's Avatar
I doubt they make a recording of it to prove it to acura. Your dealer is an a-hole. Maybe find a recording only and tell them that you recorded it.
Old 11-12-2013 | 09:33 PM
  #10129
iCrap's Avatar
Yeah i thought about that but not sure if they would accept that as proof..
Old 11-12-2013 | 09:43 PM
  #10130
ATLBuckeye's Avatar
So the reason it grinds is that the VTC actuator is draining of oil when the car is off. The grinding you hear is unlubricated VTC actuator trying to work. This is bad. It only lasts a few seconds because it fills back up with oil after a fraction of a second. It could cause some more serious issues down the line as it will wear at an accelerated rate. I know its more than you asked for but you may just have to be relentless and keep bringing it into the dealer until they find it or stop being lazy a-holes. Hopefully they arent charging you a diagnostics fee every time.
Old 11-12-2013 | 09:51 PM
  #10131
iCrap's Avatar
Yeah i knew that. That's exactly what i told them i read what was happening and she said it's a TSB meaning she is not required to do it for me. And unless it does it on-site there is nothing she can do because it is "policy."
I gave them the car on friday and it sat until monday... but they called said it didn't do it. I told them to leave it till this friday and hopefully it will grind again and they will fix it. I think they are currently working on diagnosing the parasitic draw issue...
I just passed the factory warranty (50k) but i still have powertrain warranty (70k). also i had them document the issue in the system before warranty is up. I don't know if they will charge a fee but i really hope not.
Old 11-12-2013 | 09:55 PM
  #10132
UTAH TSX's Avatar
Leave it overnight on a good cold night make sure they leave it outside not inside
and you had another engine noise that went away a month or two ago didn't you ??
that was most likely the timing chain tensioner get it replaced at the same time even if you have to buy the 60 dollar part just do it trust me on this you don't want it to fail and bend all of your valves
Old 11-12-2013 | 09:58 PM
  #10133
iCrap's Avatar
Yeah i did have that noise a while ago.
They left it parked outside friday night to monday morning and it was freezing for that entire time. That's why i don't understand why it didn't make the grinding noise when they started it monday.
I mentioned timing chain to the dealer and they said not needed.... so i really don't know what to do.
Old 11-12-2013 | 10:02 PM
  #10134
UTAH TSX's Avatar
Just the tensioner not the chain they have to remove the cover to the tensioner to change the vtc actuator
Old 11-12-2013 | 10:04 PM
  #10135
iCrap's Avatar
Oh alright. I'll tell them about that and see what they say. I really hope they fix this, they have been so difficult about everything.
Old 11-12-2013 | 10:05 PM
  #10136
ATLBuckeye's Avatar
Just a thought, but wouldnt the oil be more prone to drain out if it were slightly warm? It would be more viscous and drain out quicker. Like when a warm cars oil comes out faster than when it is cold.
Weather here when i got "lucky" was ~75degrees and only sat for one night.
Old 11-12-2013 | 10:09 PM
  #10137
UTAH TSX's Avatar
Sounds like they are just being aholes they should want to do the work it pays them 2.2 hours and it takes 45 minutes to do, drive it out to salt lake city and I will hook you up with a good Acura dealer (I work at Honda they wont let me do Acura warranty work)
Old 11-12-2013 | 10:12 PM
  #10138
UTAH TSX's Avatar
True but it seems like the colder it is the more we see at my work 3 or 4 a week in the summer 1 or 2 every month
Old 11-12-2013 | 10:13 PM
  #10139
iCrap's Avatar
I'll see what they say when i go back on friday. If not i may have to try another dealer... There are 2 others i can try.
Old 11-12-2013 | 10:14 PM
  #10140
UTAH TSX's Avatar
Sounds like a good plan find one that actually wants to work
Old 11-12-2013 | 10:18 PM
  #10141
ATLBuckeye's Avatar
Good luck! It would kill me to have something under warranty that they wont fix.
  #10142
iCrap's Avatar
The thing im worried about is apparently service records do not trasnfer between dealers. and i am past factory warranty but they will still fix this for free under the warranty if the find it. The dealer i go to now can pull up the record and see i was there previously for the issue, but the other's cant. so i don't know if that will cause problems.
Old 11-12-2013 | 10:27 PM
  #10143
ATLBuckeye's Avatar
Drop the loyalty card. Say that the other dealership was not as understanding and are considering switching (i probably would). Dealerships should have to fight for your loyalty in my opinion...
Old 11-12-2013 | 10:31 PM
  #10144
iCrap's Avatar
Yeah i should. Only reason i'm going to this one is it's 2 minutes from my house and it's where i bought the car.
Old 11-12-2013 | 10:33 PM
  #10145
ATLBuckeye's Avatar
Wow. Bought your car there and they wont help you out. Thats a blemish on their resume to me.
Old 11-12-2013 | 11:06 PM
  #10146
iCrap's Avatar
Yeah its some BS. The service there so far has been pretty poor.
Old 11-13-2013 | 01:45 AM
  #10147
PyroDave's Avatar
talk to the service manager(the one in charge of the department) or speak with the GM. tell them you want a print out of all services rendered. then tell them that you are going to another dealership, and don't be afraid to throw around words like Acura Customer Relations, Corporate, Fraud, and lawyer. always fun for shits and giggles when you dont get your way
Old 11-13-2013 | 01:54 AM
  #10148
iCrap's Avatar
Tried part of that. Service manager didn't come out even. (they said they paged him)
Said I would call Customer Relations and they were like "go ahead they won't do anything"
But i'll try again on Friday (or whenever i go back). Hopefully i can get them to fix it....
Old 11-13-2013 | 09:32 AM
  #10149
opboarding's Avatar
Everyday I'm rofling
Morning, guys and gals!
Old 11-13-2013 | 09:37 AM
  #10150
hey ryan!
any vacationing this holiday season?
Old 11-13-2013 | 10:32 AM
  #10151
opboarding's Avatar
Nothing big planned other than Houston for turkey day and christmas. I will be taking the whole week for christmas so there will be plenty of time for me to get out to a meet if there is one.
justnspace (11-13-2013)
Old 11-13-2013 | 10:37 AM
  #10152
i'm road trippin it to Floriduh Thanksgiving week.
I'll be free for Christmas break, if you wanna do Pho again!
sidebar: any one from Floriduh wanna hangout?
Old 11-13-2013 | 10:55 AM
  #10153
opboarding's Avatar
Pho sounds good.
Lots of cool Floridinians here, Joeblow, Savclaude, Baozzer etc.
Old 11-13-2013 | 12:09 PM
  #10154
JDMaccord3.5's Avatar
are you coming to the meet on the 24th?
Old 11-13-2013 | 12:13 PM
  #10155
yep, Austin and rockstar set that up, Just for me!!!
I'll leave the 22nd and get into Floriduh the 22nd. Fort Walton. 9 hour drive.
then the 23rd, i'll drive to Orlando, and I'll wake up early on the 24th and head to deerfield beach.
Old 11-13-2013 | 05:53 PM
  #10156
opboarding's Avatar
Justin is so important, he gets meets set up for him
Old 11-13-2013 | 05:59 PM
  #10157
Harper's Avatar
Unregistered Member
Of course, people need their coke fix from the crab.
Old 11-13-2013 | 06:42 PM
  #10158
wasnt the dallas one set up for me too?
too bad i didnt tell any one i was going to new york...I was boo'd up. lol
I'm headed to Boston in April if any one wants to hangout
Old 11-13-2013 | 06:45 PM
  #10159
i got angry at harper and then I looked at my avi......
Harper (11-14-2013)
Old 11-13-2013 | 10:03 PM
  #10160
opboarding's Avatar
lol yeah, pretty much
Quick Reply: 2G TSX Chat, Chit, and General Info Thread
