2G Automatic Transmission Fluid Amount
Hi All,
I just want to know how much ATF does our engine (2G-TSX Auto) need for just a fill and drain. Been searching through the forums and the closes thing I get is from these two guy.
https://acurazine.com/forums/2g-tsx-problems-fixes-145/changing-transmission-fluid-2g-tsx-861247/
https://acurazine.com/forums/2g-tsx-2009-2014-143/transmission-fluid-change-09-auto-741143/
Just want to note the correct info down so when the time comes I know how much to buy and put in. Thanks
here is what Acura says regarding fluid capacity/specs..
A/T Fluid Capacity
Change 2.6 US qts (2.5 L)Total 6.9 US qts (6.5 L)
Automatic Transmission Fluid Type
Type Use Honda ATF-Z1
Use only Acura ATF-Z1 (Automatic Transmission Fluid). Do not mix with other transmssion fluids.
Using transmission fluid other than Acura ATF-Z1 may cause deterioration in transmission operation and durability, and could result in damage to the transmission.
A/T Fluid Capacity
joflewbyu2
Oct 8, 2015 11:16 AM
, thanks for the info.
