2012 TSX wagon high speed cruising
got the wagon 2 weeks ago, I like everything on the car except when driving on highway, say around 60 and up, it has this vibration feel on the steering that makes me think something wrong with the suspension. This is bothering me a lot, do you guys have the same experience? Please post your thoughts or suggestions.
kitt1126 (03-16-2012)
I agree. It shouldn't be doing this after 2 weeks. Perhaps the dealer forgot to balance the wheels and/or do a proper alignment.
car has 400 miles now, done alignment at the dealer 2 days ago due to steering not straight and would slightly pull to the left, steering feels a bit better but viration stays when on higher speed. anyone else?
i had my wagon on the toll road the other day. speed limit is 75 so traffic goes about 80. I had a buzzing/vibration hit at 80. I am going to have my guy check the Balance on the wheels.....
this is just happening to me everyday drive to work, 20 miles on highway, vibration all the way and feels every little bump.....
But what about the road noise/ any solutions for that?????
Have the tires road force balanced. I'm without vibration an every legal'ish speed.
Alignment won't fix a wheel balance proble. Ask them to road force balance it.
If that doesn't fix it then there is something bent or severely out of whack - why was your steering wheel off center - was it from new or did you hit a pothole.
Oh, for those unfamiliar with road force balancing.
Received 2,329 Likes
Over 7500 miles on the wagon, smooth as my previous RL.
Definitely have it taken in, under warranty. Don't pay a dime. It should drive smoothly!
Well dealer has adjust the alignment again, did with the road force balancing and found nothing wrong with tires, hit traffic going home today so didn't get a chance to really get pass 65 long enough, will know in the morning. What if still exist, what can I do next?
They have to make sure its fixed.
ok, I have drove my co-worker's new 2012 TSX sedan today and feel the same vibration I'm having, except it's slightly less and steering not as stiff as mine. and he drove mine said nothing wrong, it's just how a TSX drives. I guess I have to adjust from German to a Jap made cars. now it makes wonder maybe it's the new EPS system. case closed.
at year 2000, i have my GTI VR6 with no issue when new, in 2006 A3 2.0T with no issue, only this tsx wagon does it. I really don't think any new cars should have this vibration.
maybe i should try put on N when on highway see if vibration still exist.
And that should be the case. There must be something wrong with your car. It has nothing to do with German vs Japanese cars. I've driven and owned both and there should absolutely no high speed vibrations unless something is faulty. I've done tons of highway cruising and passing in my wagon, which is almost a year old and with just under 10k miles, and have never felt anything like you are describing.
After I hit 2k miles last week I had the opportunity to drive my car on a privately owned 5 mile road and only had the faintest of vibrations (that felt more like an up/down vibration) at 90mph that could well have been because I have winter tires on the car.
Ask the dealer to put the wheels on a road force machine without first removing any of the weights. That'll tell you if the wheel/tire combo currently has an issue. Thereafter they can yank the weights and do a road force balance.
I know that my car had a balancing issue initially but the tires came off within 50 miles for (un-needed) winter tires.
kitt1126, may I ask what car you were driving before the TSX?
Graphite Ghost
That's not good. With bad roads it is sometimes difficult to determine what is road and what is vibration, but it never should be that bad.
I highly doubt the local Acura dealer has a road force machine or is that standard for Acura????
I am going to have to eat a road force of about a hundo if I want it done.
Damn, I really wish we could edit messages. kitt, please disregard the question, I see you already answered it above.
that's what they did on my tires found nothing wrong with the balance, as that's what I was told by the service advisor.
Something is clearly wrong. If theres any vibration you should feel is the leastbit, if your dash is rattling sometings wrong. It needs a trip to the Dealer
Thanks. I understand road force. Had my jeep done. Only one wheel needed to have tire rotated the rest done with weight.
Graphite Ghost
Mile High Honda has one so I suspect that Acura has one too.
wow.
Thanks Ceb.
I am going to get to 1k miles and bring it in for a check. It done it every day when I get over 80.
Well if the wheels are balanced, then starting looking at the tires as the next culprit. I would do a front to rear tire rotation to see if that would eliminate the vibration. Anither possibility, although remote is bad or lose motor/transmission mounts. If that is the case, when you start your car, you should hear a clatter momentarily. If all checks out, I would wager the CV axels as being out of balance (slightly bent or damaged).
Before anyone jumps all over me, VA's speed laws consider 20 over, or anything over 80 to be reckless driving. In VA, reckless driving can (and often does) involve getting cuffed and stuffed and spending a night with Bubba - along with getting your car impounded.
Accordingly, no Northern VA dealer is going to address a "it does it when I hit 80" problem.
Oh, and if you everget a reckless driving ticket in NoVA, don't drive to your mandatory court appearance. I know of two cases where the offender was sentenced to 30 days in jail and immediately dragged away. I doubt that he fed the meter with enough coins.
Wheel balancing issues generally occur at multiple speeds. A vibration at 80 should also be felt at 40, then go away, to return at 80 and so forth.
In general, a vibration you feel as a side to side movement in the steering wheel is the front tires/wheels, while a vibration you feel in the seat of your pants but less so in the steering is a problem with rear balance.
sent an email to the sales, he has made me an appointment again to go in early Monday monrning, this time will have the service manager to test drive with me, wish me luck. hope the manager can solve the issue.
In regards to your concern about road noise, i have a 2012 Tech sedan that is a very quiet car. I live in a colder climate and I always undercoated my cars. In addition to the protection that offers, it also further dampens road noise. On a decent to good road, the car is very quiet. I have driven an Audi 5 and did not notice any difference in road noise. BTW, never had anything remotely like your vibration issue and have owned a 2009, 2010, and now 2012 TSX. Sounds very much like a defect related to your car, or perhaps the wagon.
Late to this thread, but I have 4000+ miles on my wagon. No noticeable vibrations. The wagon is so quiet and smooth, I have gone to 80 mph with realizing it, and had to back off.
kitt1126, unless you are extraordinarily sensitive, something is amiss with your vehicle. Hope it all works out for you.
