2011 Automatic Headlight Sensitivity
Old Feb 27, 2011 | 11:09 AM
arktctr's Avatar
This may be a bit too specific a question but does anybody know what could possibly be causing the automatic headlight sensitivity to be so touchy? I came from a 2009 TSX and had it set to "High" and it seemed to only come on when it should (i.e., the sun was setting, tunnel, etc...). I have had to set my 2011 TSX to "min" and it still triggers the headlights at even the slightest shadow. It goes on and off all the time during daylight conditionas and is basically far too sensitively compared to my 2009. And yes, I know I could just use them manually, but I wondered why this would/could have changed between the two cars? Thoughts?
Old Feb 27, 2011 | 11:24 AM
TSXKid2010's Avatar
SEEYOU2CREW
Try putting it onto "High" and see if the scale was reversed?
Old Feb 27, 2011 | 01:07 PM
TSteezyX's Avatar
Set your new TSX to "high" as opposed to "min"...
Old Feb 27, 2011 | 04:37 PM
fxcarden's Avatar
I just did a test in my driveway, and it seems that when set to "max", the lights come on by just being in the shade. When set to "min", they stay off.
Old Feb 27, 2011 | 06:58 PM
arktctr's Avatar
Thats how I would assume it would work as it worked that way on my previous TSX...hmmm...wonder if maybe something is wrong with the sensor?? Oh well...thanks for checking...
Old Feb 27, 2011 | 07:03 PM
KillerG's Avatar
Op is too busy to care
you could always do it yourself a solution by covering the sensor in a semi-transparent filter thus making it less sensitive to light
Old Feb 27, 2011 | 07:09 PM
PyroDave's Avatar
or take it back to the dealer and be like hey guys... that aint right lol
Old Feb 27, 2011 | 07:11 PM
KillerG's Avatar
yeah maybe if you bring up the issue next time you visit and other people do too then we can have change!
change we can believe in
Old Feb 27, 2011 | 09:37 PM
TSXKid2010's Avatar
SEEYOU2CREW
Where is the sensor anyway? In the headlight?
Old Feb 27, 2011 | 10:34 PM
KillerG's Avatar
its right at the end of the dashboard if i am correct, inside the car
Old Feb 27, 2011 | 11:26 PM
pbhak002's Avatar
Obama 2012 "change we can believe in"
KillerG just found President Obama's new motto in 2012. LMAO
As for the auto light sensitivity i have a '10 and min vs max for me almost the same. Doesn't really bother me though
Old Jan 18, 2018 | 07:27 PM
macuratsx's Avatar
Hey everyone... I am having a similar issue with my 2010 TSX. My auto headlights are ALWAYS on. Even though they are set to "auto," they never shut off, even in direct sunlight. I looked through my owner's manual and it shows me a step-by-step of how to change the automatic headlight sensitivity, but then in small print it says *Except on the Canadian TSX 4-cylinder model* ... which is the exact model that I have. I do not have that option in my "setup" menu. Does anyone know how to adjust this sensitivity an alternate way on the 2010 TSX Canadian 4-cylinder model? There must be a way... I would hope at least... if not, does anyone have any other suggestions to fixing this? Thanks in advance.
Old Jan 24, 2018 | 10:29 AM
macuratsx's Avatar
Nevermind... I figured it out. Thanks
hashbrown
Feb 18, 2022 11:20 AM
Houston
Oct 8, 2015 01:27 AM
rockyboy
Sep 29, 2015 12:05 AM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
