100,000 mile service - any additional items?
Just crossed 100,000 miles in a 2011 6MT Tech.Still has the original brakes and clutch! Probably because I drive it like a baby stroller.
Here's what I am planning for service, except for brake fluid and spark plugs, both changed at 85k. I change my oil with Mobil 1 every 5k.
Here's what's recommend around this mileage:
What else should I have inspected or replaced that is not on the Maintenance Minder?
What other item needed inspection/replacement when your 2G hit this milestone mileage? Tks.
- Oil + filter (last 95k)
- Transmission and clutch fluids (last at 70k)
- Coolant (last at 55k)
- Engine and cabin filters
- Alignment and tire rotation
- Full detailing
- Drive belt
- Valve clearance adjustment (if noisy)
- EGR valve?
- PCV valve?
- Timing chain tensioner?
