A124 service
Old Sep 24, 2013 | 12:09 AM
phishfood's Avatar
A124 service
Traveling and tried searching rl forum for this.
Anyone know what an A124 entails and what pricing may range?
Old Sep 24, 2013 | 12:13 AM
phishfood's Avatar
Okay that's weird ... 4 is timing belt n plugs n water pump but I just had that done. Swear I had a B4 showing why would it give me a 4 again?
Old Sep 24, 2013 | 07:47 AM
HEAVY_RL's Avatar
you want us to explain why your car thinks you need a timing belt or why you did it early when it didnt ask for it?
And to answer the 124 question:
Maintenance Minder A Scheduled Maintenance
Recommended service: Replace engine oil
Maintenance Minder B Scheduled Maintenance
·Replace engine oil and oil filter
·Rotate tires
·Inspect front and rear brakes
·Check parking brake adjustment
·Visually inspect tie rod ends, steering gear box, and boots
·Visually inspect suspension components
·Visually inspect driveshaft boots
·Visually inspect brake hoses and line (including ABS)
·Visually inspect all fluid levels and condition of fluids
·Visually inspect exhaust system#
·Visually inspect fuel lines and connections#
#: See information on maintenance and emissions warranty in the first column on page 212 of your owner's manual.
Maintenance Minder 1 Scheduled Maintenance
Recommended service: Rotate tires
Maintenance Minder 2 Scheduled Maintenance
·Replace air cleaner element
oIf you drive primarily in dusty conditions, replace every 15,000 miles (24,000 km).
·Replace dust and pollen filter
oIf you drive primarily in urban areas that have high concentrations of soot in the air from industry and from diesel-powered vehicles, replace every 15,000 miles (24,000 km).
·Inspect drive belt
Maintenance Minder 3 Scheduled Maintenance
Recommended service: Replace transmission fluid
Maintenance Minder 4 Scheduled Maintenance
·Replace spark plugs
·Replace timing belt and inspect water pump
·Inspect valve clearance
Maintenance Minder 5 Scheduled Maintenance
Recommended service: Replace engine coolant
Notes:
·Independent of the maintenance messages in the multi-information display, replace the brake fluid every 3 years.
·Inspect idle speed every 160,000 miles (256,000 km).
·Adjust the valves during services A, B, 1, 2, or 3 if they are noisy.
Old Sep 24, 2013 | 10:56 AM
MrKev's Avatar
To simplify it
A - Oil change
1 - Tire rotation
2 - Air and cabin filters
4 - T-belt service, spark plugs and valve adjustment, in your case you just need valve adjustment
Old Sep 24, 2013 | 11:32 AM
oo7spy's Avatar
Originally Posted by phishfood
Swear I had a B4 showing...
I bet you didn't.
If it has been done, rotate tires, change filter and oil, and call it a day.
Also, where is your manual?
Old Sep 24, 2013 | 12:27 PM
phishfood's Avatar
Nope, def had a B14 on prior service
Here's my post from back then saying so:
https://acurazine.com/forums/showpos...9&postcount=19
So MID definitely gave me a 4 code two times in a row.
Old Sep 24, 2013 | 03:02 PM
oo7spy's Avatar
Maybe Mr Kev is right.
Old Sep 25, 2013 | 03:10 PM
phishfood's Avatar
Originally Posted by MrKev
To simplify it
A - Oil change
1 - Tire rotation
Hmmm, thanks. Going to check my receipt don't think they did valves.
Old Sep 25, 2013 | 06:01 PM
miner's Avatar
Valves only adjusted if noisey
Old Sep 25, 2013 | 06:57 PM
MrKev's Avatar
If you're wondering if valve adjustment actually does anything it will make your car run a lot smoother and more quiet. But it's not something that you have to do at 105k
Old Sep 25, 2013 | 09:24 PM
oo7spy's Avatar
Is it something the car could recognize?
Old Sep 26, 2013 | 07:10 AM
sOLLEx's Avatar
Usually around 100k miles, the valve clearance on most tends not to be too far out of spec. Most people will not be able to tell the difference if they were just barely out. Usually around 150k miles is when you really start to notice a difference if they have never been done. When they get too tight, fuel consumption goes up caused by running richer, and will eventually misfire at idle. Depending on the generation of model, the PCM will more closely monitor excessively lean or rich condition due to emissions regulations. The 1st gen MDX will sit there and misfire all day while the 2nd gen will set a lean condition or rich condition code that will turn the CEL on way before it gets too rich or lean to start misfiring and ruining the converters. It's a good rule of thumb to get the valves clearance checked/adjusted at 100k but not necessary. You won't save any labor by doing the timing belt replacement during the valve clearance adjustment because you don't have to have the timing belt covers off in order to see the cylinder markings on the front cam.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
