will 205/55/16 fit on stock TL wheels?? 2nd gen.
Try using DiscountTireDirect.com
It'll tell you various options.
http://www.discounttiredirect.com/di...URA&vid=004933
Ruf
Ruf
If you click on the URL I posted it'll show you the original tire size and then a bit further down it'll show the optional tire sizes.
Plus Zero
- 215/55-16
- 225/55-16
As for the 205/55/16s, they will work . . but your speedometer will be about 1 or 2 miles off . . so instead of reading 50mph, it'll read 51 or 52mph, but your actual speed will be slower. The upside is that you'll get a little better handling, acceleration off the line and it can even boost your in-town gas mileage a tad. The reason is that the 205/55s are lighter (1-2lbs) than the 205/60s.
Ruf
Plus Zero
- 215/55-16
- 225/55-16
Ruf
Size 215/55R16
Load Max. Load Index 93 = 1433lbs (650kg) per tire
Service Rating: Speed Rating “V” = 149mph (240kph) 93V SL
Treadwear: 440
Traction: A A
Weight 26lbs
Width Sect. 8.9"
Dia. 26.3"
Revs Per Mile 795
While not a bad tire . . . it's very heavy. It will give steering response a heavier feel. It will increase your breaking distance. It will slow down your acceleration. Reduce gas mileage. Unless you're really not concerned with these things I'd look at some other tire options.
Ruf
Treadwear: 440
Traction: A A
Weight 26lbs
Width Sect. 8.9"
Dia. 26.3"
Revs Per Mile 795
Ruf
Size 215/55R16
Treadwear: 440
Traction: A A
Weight 26lbs
Width Sect. 8.9"
Dia. 26.3"
Revs Per Mile 795
Ruf
Treadwear: 440
Traction: A A
Weight 26lbs
Width Sect. 8.9"
Dia. 26.3"
Revs Per Mile 795
Ruf
i had only heard good things about the eagle gt's guess not...
where did you get this info? what about the G019 Grids?
mtl_ilx
09-03-2015 09:58 PM
