What's our offset?
Bippu Style only please
You're able to fit much more aggressive offsets on there, just no-one wants to do the "extreme modification" of rolling fenders and cutting tabs. lol.
If you're gutsy, you could fit a 8.5" width with a +37 offset. You'll have to run camber on it, but it will fit. I'm currently waiting for a set like this to pop up on memoryfab or jdmwheels so that i can get my sickness on.
But yeah, if you don't want to take the "hassle" to do the modifications needed for such an agressive offset..... what philly fresh said would work.....
Thanks phrost. I know flush is relative, but if it's not flush flush, it just doesn't look right to me.
By flush, I mean slammed, cambered to a nice tuck, and the rim sitting just millimeters from the fenderwall.
And believe me, I know many aren't up to it. I don't see what's so hard about renting a fender roller and doing it yourself, or even going the route of a rubber mallet to roll the fender with a high power blow dryer.... Call it ghetto if you will but them wheels will fit!!!
I wouldn't be surprised if you could fit a 8" width with a +32 offset, the only reason I say 8" is because I dunno if you'd have to roll more than -3 on the camber for it to fit, and no-one wants to hit a strut tower.
-Arsenic-
-Arsenic-
Circled in red is the area cut out to"cut tabs". The area in blue is an extra piece I had to remove due to my low offset and agressive drop. In yellow, is the lip of the fender. This is what you "roll", you roll it flat with the body so it doesnt stick out, makeing more room for clearance. I also had to do that.
And yes, if the offset is too high you can correct it with spacers, but it is also reccomended you get longer studs for this as well. Hope this helps.
![](http://a488.ac-images.myspacecdn.com/images01/3/l_16ff04ee23ebc6f8a46b34568039bb3f.jpg)
-Arsenic-
Originally Posted by myTaLizaS3.2
what bolt patterns should i look for to avoid any modifications if I wanted to get rims? 18 inches are fine right?
Keep it flush!
-Arsenic-
Originally Posted by djescobar973
thanks for the info 02type-s, the 19x8s are onthere way........ going for that "agressive" look too...
We are on the same page then bro!! Cutting the tabs, and rolling fenders is real easy..Im not sure why people here like the sunken in wheel look!? I like the rim poking a lil bit passed the fenders, tires tucked behind it.. You can try a bunch of fitments but you gotta be slammed.. On coils its safe to say, you can run a 9" up front 9.5" rear...Or you can just run straigh 9"s all around, do your math with the offsets to figure out where youll sit flush....
Received 1,080 Likes
Our bolt pattern is 5x144.3 and the wheel size all depends on offset and width.
Actually the bolt pattern is 5x114.3
TLP/CLP wheels: 16x6.5 +55
TLS wheels: 17x6.5 +55
CLS wheels: 17x7 +55
-Arsenic-
Oh man, I hope we're breeding a new set of Gen2 TL owners with the talks of wide/low offset wheels.
I'm with prhost, I can't stand high offset wheels because of the sunken in look.
I will do my best to find the most aggressive width/offset I can find when I do wheels. I want as much lip as possible.
Sure it'll need a fender roll and tab cutting, but that's child's play compared to what I've seen people do to get wheels to fit on cars.
-Arsenic-
see whats you started 02type-s... lol..
I can't stand it when ppl call it "major body/metal modification". lol if that is "major" to you maybe you should leave your car stock. All you are doing in bending a piece of unused metal out of the way, it takes MAYBE 10-15 min per side. As long as the metal is warm, the paint should stretch and not crack.
For my wheels, there were two offset choices available, 40 and 42. I of course opted for the 42, but how can I make sure they really ordered the correct ones? They are 16x7 TSW Catalunya wheels.
Also with it being a 16x7 you shouldnt have any issues.
Thanks, I'll check them out when I remove them to mount my winter tires on my OE wheels.
I wanted to go with a 225 size summer tire next season, but as it is now, with the new wheels the tires are about flush with the fender. I don't want them actually sticking out beyond the wheel well (running 215/55R16).
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
