Tire Rubbing Has Caused A Problem
Old 03-21-2005 | 08:24 AM
slikz's Avatar
1999 Acura 3.2 TL
Well I have had my car dropped on Tein S.Tech for awhile now. Just today my friend noticed something, the plastic wheel well thing, is coming off. The grommet on the top has came off. I felt the metal right above the tires where the grommet goes in and holds the plastic thing in place and it is bent inwards. I don`t know what to do, it looks really messy with the plastic thing hanging down from the metal fender line thing. Does anyone know how to fix this? It happened on both sides.
Old 03-21-2005 | 08:26 AM
NSXNEXT's Avatar
Are you running stock wheels?
Old 03-21-2005 | 08:31 AM
slikz's Avatar
1999 Acura 3.2 TL
No I am not. But I am running my stock tires on the wheels. They are 16"s, and fit my old tires which were on the stock wheels. So I am sure it is the right dimensions, no?
Old 03-21-2005 | 08:59 AM
ou sig's Avatar
Boomer SOONER
Mine also rubs on the front when I am turning and hit a bump. I would say the stock shocks cant respond quick enough with the lowering, so aftermarket shocks may be the best way to go for you
Old 03-21-2005 | 06:10 PM
slikz's Avatar
1999 Acura 3.2 TL
Yeah. But rubbing isn`t the problem right now. I just need to find a way to somehow make it so that the plastic wheel well cover thing isn`t hanging off of the fender. It looks really ugly. Does anyone know how to fix this? I just bought some new grommets to fit it back in but the grommets won`t snap in because the metal that holds it is bent inwards. It`s just hanging there. My friend said to super glue it but I can`t because I have side markers installed and I need access to the back of the fender for the wires.
Old 03-22-2005 | 03:44 AM
Lawaia's Avatar
Moderator Alumnus
How about using rivets to hold it in place
Old 03-22-2005 | 10:11 AM
REDLINEN's Avatar
Missing my Acura's
Happend to me but I had all the plastic replaced end of the problem until I put my 18's back on I guess, but im getting tein coilovers hopefully when I raise it a lil ( Im dropped 3") I wont have the front rubbing issue.
Old 03-23-2005 | 01:23 AM
slikz's Avatar
1999 Acura 3.2 TL
What are rivets? Where can I buy these?
Old 03-23-2005 | 07:32 AM
NSXNEXT's Avatar
Bend the sheetmetal back into place then pop the clip back in.
Old 03-23-2005 | 11:31 PM
Lawaia's Avatar
Moderator Alumnus
Most auto parts stores carry rivet guns with an assortment of different rivet sizes.
Old 03-24-2005 | 09:00 PM
blokhead's Avatar
PCM full of water, yummy
I have the same problem on small bumps or dips when I'm turning.. it isn't much... But I'm putting on my eibach sways tomorrow, hoping that it will stiffen up the front just enough to prevent the slight rub I have front.... i'll let you know.
Old 03-25-2005 | 10:52 PM
slikz's Avatar
1999 Acura 3.2 TL
Okay, thanks blokhead. How much are sways btw? And bending the sheetmetal back into place, how would I do this? This thing is pretty hard to bend back into place.
cycdaniel
12-17-2019 10:58 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
1lowtc
1G RDX (2007-2012)
15
11-19-2015 10:52 AM
bailey24
08-31-2015 05:38 PM
darknite123
Integra
08-30-2015 03:00 PM
Quick Reply: Tire Rubbing Has Caused A Problem
