Tein SS and Chamber
Former Sponsor
It really depends on how much you lower the vehicle. Your best bet is to install the TEIN SS and lower it to where you want it. Then go get an alignment and see how far you are off. Usually most companies will allow you to get a free re-alignment within 30 days if they can't align it properly.
If you need the TEIN SS or Ingall's camber kits PM me.
Former Sponsor
Originally Posted by Sushiplease
From what I know of the SS, you will need a camber kit for the front and rear. Unless you teins come with a Pillow Ball Top Mount w/ adjustable camber.
This is an example from Ksport coilovers
depending on how much you lower it usually you can get away with only the rear. i have mines dropped and when i got alignment at sears one of the guys there use to work for acura in oahu and said the front is fine the rear is way off though. so i bought the rears and had it installed. i still need to go back and realign it again. haha. its been like 3 months already heehee. but its easy to install. do the coilovers and the camber kits all at the same time. while the whole car is apart. much easier.
Originally Posted by Phrosttz0
x2
my car is lowered on coils, with a little less than a 2 finger gap all around. When i had it aligned, front camber was perfect, rear camber was off just slightly, but not enough to cause any serious wear on the tires. Just remember to have the toe correct and you shouldnt have many issues.
However, if you ride slammed as hell like z3ro, you might have a little different of a story
Originally Posted by SSMTL01
x3
cmon you can do better, no finger gap!
BoricuaTL
04-08-2016 01:08 PM
lanechanger
10-13-2015 10:56 AM
4drviper
09-23-2015 07:42 PM
