Suspension Overhaul Help
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
What's up guys. I'm planning on dropping my vehicle with tein s.techs and koni shocks. My question is what else should I change to do a complete overhaul. I have 160,00 miles and need new axles. I'm thinking ball joints and inner tie rods, since I just changed my outter tie rods. Should I change control arms? Unless they're bad. Any suggestions? I don't wanna get my new setup and have problems in a short time. Thanks in advance.
I need 2 more gears
don't replace your lower control arms unless they are manged, which is nearly impossible to do they are very stout and rugged. This is what I changed around the same mileage as you.
Shocks
springs
sway bars
end links
lower ball joints
upper control arms and ball joints
strut mounts
tie rods (inner and outer)
Axles and CV joints shouldn't need to be changed unless there is noticeable play or excessive noise coming from them. I think the above covers pretty much everything you need to concern yourself with.
Shocks
springs
sway bars
end links
lower ball joints
strut mounts
JSekai (11-25-2013)
I need 2 more gears
Also adding a cusco lower frame brace is a cheap and good mod to have. Don't forget the rear arms either. Rear sway bars and Moog end links are a must have and toe arms are good to replace too as they seize after years and years of driving and if you can't adjust those then you can't get a proper alignment.
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
