staggered wheels question
Old Apr 25, 2005 | 02:58 PM
ryguyGTSK's Avatar
Question staggered wheels question
so i finally dumped my car and im looking on getting 19s on front and 20s on back of my 02 tls.. has anyone done this.. if so what size wheels and tires.. i want a about a 1 in lip on front and maybe a 2 inch lip on back if posibile.. doesn anyone have pics or any info of this.. thanks everyone
Old Apr 25, 2005 | 03:25 PM
derrick's Avatar
Why would you want a staggered setup on a FWD car? 20s can be done ... but you will be 4x4 (no way you can lower your car on 20s). If you want deep dish (ie lip) ... make sure the offset is high (+48 or more). I know Axis Mod Se7ens have a lip. Good luck.
Old Apr 25, 2005 | 04:43 PM
ryguyGTSK's Avatar
just for show.. thats the only reason i want to have the 20"s on back.. i know its not going to help me since the cars fwd.. thanks for the info tho.. anymore help would be great
Old Apr 25, 2005 | 05:13 PM
i would go no on the staggered, even if for show...it would just straight up look weird. usually just the width and offsets are adjusted, not the size of the whole rim. 19x8 fronts and 19x9 in back. i'm just sayin, don't go and do it though
my tl has a crazy offset on the wheels, makes it look like it has a deep dish, but its hard to find rims with a +55 offset
let me know if u wanna see some pics.
Old Apr 25, 2005 | 07:07 PM
mkomaee's Avatar
a tl or a cl can be dropped on 20 heres mine to show ya
Old Apr 25, 2005 | 10:40 PM
REV-01's Avatar
[QUOTE=derrick]if want deep dish (ie lip) ... make sure the offset is high (+48 or more). QUOTE]
i don't understand this, the higher the offset the less lip you will have.....not the other way around
Old Apr 25, 2005 | 11:26 PM
shinho04's Avatar
That's what I thought also. The lower the offset or even negative offset will have the bigger lip.
Old Apr 26, 2005 | 02:37 AM
Lawaia's Avatar
Moderator Alumnus
Lower offsets doesn't always mean that there will be a lip. It is all dependent on the wheel design. But traditionally speaking, a higher offset will lessen the probability of a large lip.
If staggered is what you're looking for, I say go for it.
Old Apr 26, 2005 | 09:40 AM
ryguyGTSK's Avatar
hey i likes those rims.. im not really going for 20's all around tho.. do you got pictures from the side view??
Old Apr 26, 2005 | 01:31 PM
derrick's Avatar
Hey REV-01 ...
You are absolutely right ... you need LOW offset to get major lip. However, if you do that for our high offset cars, you will have rims stick out way beyond the wheel wells and get all sorts of other issues (rubbing, etc). The only set of rims I know that has a 'deep dish' and a high offset are Axis Mod Se7ens.
I just wanted to warn this guy if he wants a deep dish, his choices are limited for our applications.
Thanks for correcting me. Sometimes I type way faster than I think.
_____
Hey mkomaee,
You also proved me wrong with 20" rims ... I guess you can be lowered on TL/CL. Any issues with rubbing? I don't venture over to the CL forum very often. I've only seen some (horrible) applications of 20s on a TL from time to time.
Old Apr 26, 2005 | 01:44 PM
ryguyGTSK's Avatar
i dont think im much of a fan for the Axis Mod Se7ens.. im shooting for iforges or GFG 1-5 of some DPE R05 Variant S rims.. but who knows.. i guess ill call up iforged and see if they got any aplications with high offsets with our car.. thanks everyone..
Old Apr 26, 2005 | 02:25 PM
NSXNEXT's Avatar
iForged and DPE can pretty much make you anything you want......for a $$$
Old Apr 26, 2005 | 05:51 PM
REV-01's Avatar
how much lip does the axis mod 7 got? i just pick up another set of 19's, it had even more lip than my current work wheels....is about 82mm lip.
Old Apr 27, 2005 | 02:18 AM
Napsoner's Avatar
20's can fit on the tl, but it will look stupid. The wheels will be so damn big and the car lines won't flow right for that rim size.
Old Apr 27, 2005 | 02:27 AM
Bread-A Spec's Avatar
08 WDP TL-S
agree.....19's is much enough on our TL
Old Apr 27, 2005 | 02:29 AM
Edward'TLS's Avatar
6G TLX-S
The tires are too narrow for the 20" to look good. Only wide tires of at least 275 + will look best on 19"/20" rims. Unfortunately it will be too wide for the TL.
Old Apr 27, 2005 | 09:56 AM
ryguyGTSK's Avatar
damn.. everyone is breaking my heart today.. hahah.. my dreams have been shattered... i guess no staggered wheels for me.. =(
Old Apr 27, 2005 | 10:04 AM
ryguyGTSK's Avatar
i got a friend with a matrix that doesnt look that bad with 19' and 20's.. his is also fwd.. check it out.. hes also running some iforges..
Old Apr 27, 2005 | 04:06 PM
REV-01's Avatar
matrix could do a wider wheel, my employee drives a matrix, i ordered a set of work wheels for his car. i think i order 9.5 for the rear
Old Apr 28, 2005 | 02:31 PM
Edward'TLS's Avatar
6G TLX-S
A 1.8L Matrix with 9.5" rims - it will be slow like hell. Big rims need big displacement engines with lots of torque to get any decent acceleration, especially from a dead stop.
Old Apr 28, 2005 | 06:29 PM
REV-01's Avatar
yeah a bigger rim is usually heavy so you will lose some acceleration from stop light....but the 9.5 is for the rear, front i order 8.5...is for looks....if is all performance nobody would want to buy matrix...
Old Apr 28, 2005 | 06:38 PM
BiggyMcWang's Avatar
USDM UA5 A-Spec
I would do staggered, but.... I would never do 20's...... I'd do probably 19x7.5 front and 19x8 back.... although I know someone who has 19x8.5's on front and back... boku i think. He has one of the sickest rims for our 2nd gen, Axis Milanos (same as Trafficstar/Maya DTS). I wonder if his the guy that works at stereo place on corner of El Camino and 237 that I saw today... Anyway, my opinion is go staggered if you want, I would if I could roll out 3 bills for my Trafficstars.
Old Apr 28, 2005 | 07:31 PM
REV-01's Avatar
another option is high disk front and low disk rear for that staggered look
Old Apr 28, 2005 | 09:24 PM
USDM UA5 A-Spec
You mean wider front and less wide back? If so I've seen it!?! On an integ drag machine with like 400Whp.... I wouldn't do it if I were you.
Old Apr 28, 2005 | 09:56 PM
PDX3.2TL's Avatar
You will definatly be rolling fenders if you get any thing larger than an 8.5" in the rears. That is what I am running right now and it is a tight fit. Now would I suggest against it? Only if you are a purist and don't like to mod the body to make things fit. Now for the front. 8.5" are just a shade too wide. If you are going to stagger you HAVE to go with a 8" rim in the front with a 225 tire of you will be literally squeezing that thing in. It does fit, but you will have a little bit of rim protruding from the front. 19"x8.5" +45 offset w/ 225/35/19 is my exact setup with Axis Hiros.
A pic to show you. Look closely at the rear fender. The rim sits flush with the fender. It is up to you if you want to take the risk.. If you run a 235 tire to protect the rim (the rubber is literally stretched onto the rim) it will rub for sure in the front. In the rear it is questionable.
[img][/img]
Finally, do I recommed staggared rims with different sizes and offsets? NOpe. too many variables without the trials. You can see that an 8.5" wide is a tight fit. TommyGSR is running 9" with a +55 offset. You may want to try that. It will be a tight fit too. Good Luck.
Old Apr 28, 2005 | 09:59 PM
REV-01's Avatar
you could have a same size wheel front and back. but a high disk (less lip)wheel for the front and low disk (more lip)rear for that staggered look...but is actually same width front and back...this is available if you are doing high end wheels.
Old Apr 29, 2005 | 12:31 PM
ryguyGTSK's Avatar
i never heard of this called high and low disk.. but this actually sounds like it will work. im thinking of some iforge classics so they might beable to have this done for me.
Old Apr 29, 2005 | 02:29 PM
NSXNEXT's Avatar
Are you prepared for the ridicule you will receive when car enthusiasts see what you've done? The purpose of the wider wheel in the rear is for traction in rear-wheel-drive cars.
I'm still confused why you think this is cool? Maybe I'm just old.
Old Apr 29, 2005 | 02:43 PM
ryguyGTSK's Avatar
i really am not looking for the wider tire im more looking on just a bigger rim on back.. like i said i was looking into 19s in front and 20s in back.. thats all.. i know its not going to effect anything but looks.. thats all im looking for.. something different..
Old Apr 29, 2005 | 02:49 PM
Edward'TLS's Avatar
6G TLX-S
.. something different ..
ahh .. how about a Smart with 19" and 20" ? This would sure be different.
Old Apr 29, 2005 | 03:17 PM
ryguyGTSK's Avatar
im probably slow.. but whats a "Smart"???
Old Apr 30, 2005 | 09:30 PM
REV-01's Avatar
Smart is a ugly 2 seater very popular in europe
Old May 1, 2005 | 02:31 AM
Thpse Foose Speedsters look really nice on your CL man... Staggered rims/tires are meant for RWD cars only. GFG or are gunna cost you like $900-1200/rim for 19s/20s. I gotta nice 3 1/2 inch lip on my rims and their 20x7.5 wrapped in Nitto ExtremeZRs.
Old May 2, 2005 | 09:25 AM
ryguyGTSK's Avatar
can i see some pics of your tires
booma1218
May 3, 2016 07:39 AM
lland
Oct 4, 2015 04:47 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
