Shaking/Vibrating when braking
Old 01-06-2010, 06:08 PM
SD-TLRIDER's Avatar
Since this has been going on for a while, i finally changed my front brakes and rotors. Hoping that everything would be gravy it still shakes like i had warped rotors. I've read that axles may be the problem. Is it true? What other things can i do to stop this sh***. Thanks in advance for your help guys!
Old 01-06-2010, 07:47 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
When braking is usually the rotors. Did you put quality rotors on? Have your ball joints inspected. I would take the axles off the list since it only happens while braking. Looks like you have aftermarket rims. Do you have hub centric rings for them? One last thing. Your rear rotors, they can cause shaking in the wheel too. Have you had them replaced/resurfaced?
Old 01-07-2010, 02:37 PM
SD-TLRIDER's Avatar
I'm a bit low in funds right now so i purchased kragen rotors, not too sure how great they are. I'm actually on stock type S wheels at the moment. I haven't touch the rears yet. You think i should start there?
Old 01-07-2010, 04:09 PM
fsttyms1's Avatar
I would inspect things up front first. Look at ball joints, make sure wheels are tight and not over torqued. Look for discoloration on the rotors to see if they are glazed over causing the shake. Did the shake go away at all after the change of rotors or no?
Old 01-07-2010, 04:34 PM
SD-TLRIDER's Avatar
^^ After replacing the front rotors, shaking is still there. I do want to mention that the front right rotor is missing the set screw that holds the rotor. I was told by a friend that its not a big deal since my lugs are properly torque. Is this true?
Old 01-07-2010, 05:49 PM
Tosh1's Avatar
If the rotors are brand new and you are braking them in softly...they should not be warped even if they are cheap.. I have some decent rotors I just changed out as well all 4 corners and mine still shakes a bit....
I am thinking it is my alignment.... since I got new rotors took that off my list...maybe ball joints since that has never been changed out going on 115k now..
Let me know if you find a solution..
Old 01-07-2010, 08:31 PM
fsttyms1's Avatar
Those screws arent needed or causing it. Look at the things i mentioned.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Shaking/Vibrating when braking
