Rims put on improperly?
Originally Posted by whatwasthat
well, what is an improper rim placement..?...
if lug nuts aren't tight, or wheel is out of balanced..? or maybe w/ directional tires, they are on wrong..?
What are you trying to say??
from the rear driver wheel, i hear some loud noise wen i hit a TINY bump or gas my car up juss a LITTLE BIT, maybe that is rubbing, im not sure how that sounds but was juss wondering.. thas the only tire that makes that sound and even the smallest little bump will cause that to happen
Are you lowered? If so, what kind of suspension, and how low? Camber kit present on the car? What size wheels/tires? Describe the noise a little better than "a loud noise". Is it a clunk or a grinding noise?
did u had to install centric rings before u put the rims on? check alignment, are the rims balanced? proper tire inflation?
This is actually what may help u: Did you tighen the lugs before dropping yer car? and then after dropping tighten to like 85lbs torque? did u use 5 star method to tighten?
just take the wheel out, and put it back on...if u put it on wrong, maybe its an angle or something, this can hurt u.
peace
peace
peace
peace
ok,, juss took out my rim and put it back... same problem... RUBBING GRINDING, from the looks of it, nothing looks close to the wheel to make it rub.. y do i hear the sound? although my left side of the car (driver side) sags a bit more then the other. i got brand new shocks and springs... ? someone please help
Sounds like your offset is too low, and the grinding/rubbing sound is caused by the tire hitting the rear bumber tab.
What's the width and offset of your wheels? And what size tires are you rolling on?
but from the looks of my car juss sitting there, doesnt look newhere near to neting for it to be hitting, my wheels are 18x7.5, i did call the company and they told me the offset was 45, im dropped on h&r sports. Can soemone show me a pic of the bumper tabs? im lost. thank you
rseb4agze
May 3, 2016 07:41 AM
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
merc009
Oct 3, 2015 12:59 AM
