Quick "Fitment" Question
http://www.discounttiredirect.com/di...4.3&vid=007563
7.5 / 53 offset
The Stickie says that for a 7.5, the recommended size is 45... but then again some others say you can use higher. Simple question, Would they fit?
03 TL-S
7.5 / 53 offset
03 TL-S
The sticky means that that is the ideal minimum. Any thing above that to +55 will be your best fitment with the least amount of issues.
The rim specs you posted are ideal. Tire size 225/40
^ An alternative tire size is 235/40/18 (which is closer to OEM tire circumference of 215/50/17 tires) but has greater potential to cause rubbing. 225/40/18 has slightly less sidewall protection and more chance for bumpier ride ... 235 is a little grippier / possibly louder / slightly more expensive $ ... pros and cons to either size.
