Off-set questions
Off-set questions
Hi..
I tried search engine to find an answer, but it wasn't easy.
Would 17 x 7.0 with +43 offset fit perfectly without sticking out of body?
I want tucked in look..
Also, how about 19 x 7.5 with +41 offset?
thanks a lot in advance.
not sure bout 17x7 +43 probably okay
pretty sure 19x7.5 with +41 wouldnt tuck
but i cant guarantee, so wait for some more replaies
jus tryin to help, since it appears that NO ONE is on AZ today
good luck
good luck
17x7 ET43
The clearance from stut housing to the inside of the wheel will be 6mm MORE
The outside edge of the wheel will EXTEND an extra 18mm
19x7.5 ET41
The clearance from stut housing to the inside of the wheel will be 1mm MORE
The outside edge of the wheel will EXTEND an extra 27mm
Assuming 6.5 ET55 setup.
Take that!
19x7.5 ET41
Take that!
Originally Posted by mctuners
Thanks for inputs, guys..
So, 17x7 will tuck in, but not 19x7.5?
Hmm...
Thanks for help, guys...
Generally, if you were to get a set of 19 inch wheels, what offset would you get? to have them not stick outside of body? I'm running on a stock springs with tokico blues, but I'm looking to get a set of Tein SS soon or Tein H tech springs. I assume that they won't rub, but if they stick out, they probably will, right?
Hey,
So, the number of offset goes up, it sticks out more?
Originally Posted by Lawaia
Diameter is not as important as width. Max should be 8" +50 offset minimum. This applies to ALL diameters (16" to 19").
Originally Posted by SilverIce2000
question.......
what about 225/40 tires on 18X7.5 rims with 45 offset??? will that fit on an acura TL dropped on comptechs?
thanx
thanx
I understand that I need offset of minimum +50, but how about this?
19 x 8 with +43 offset?
I will be lowering my TL with tein SS or Tein H-tech soon. Will they rub?
If you understand you need +50, how in the world is +43 gonna work?
Now, I became an idiot..
Now I understand how off-set relates to wheels sticking out or going in.
One last question.. What is the maximum number that I should not exceed to go over?
I'm looking at 19 x 7.5 and 19 x 8.5 with offset +53?
I guess they should be fine, right?
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
