Need your help with choosing wheels, camber, etc
Hello,
After drop i had fitment issue with my old rims (18x7.5 +42), so had to put my really OLD stock 17". Then in few weeks realized that car is "eating" front tires (rotated them with rears for now)
I need your help with selecting camber kit and what better to do asap?
Do I need to check alignment before buying kit?
Now about the wheels, due really bad roads here, i don't want to go more then 18". The question is, is it ok to put bigger wheels on the rear, like 8.5 and 7,5-8 on the front, since our cars are front drive.
I really like that rims:
They have them in:
18x7.5 5x114.3 43
18x7.5 5x114.3 48
18x8.5 5x114.3 35
Will they fit with rolled fenders? How it's better to roll finders? i passed one body shop and they quoted me 100 per side.
And one more question. Is it looks ok? Or rubber cracked?
They have them in:
18x7.5 5x114.3 43
18x7.5 5x114.3 48
18x8.5 5x114.3 35
Heya! Can you be a little bit more specific? It's my first time doing any fitments, so trying to understand everything
with ingalls i will be able to fit 8.5 +35? jjashaa, as i remember you have 9 +35?
What about front? +43 or +48?
What does that means?
could be toe is off.
I think it will be quicker to send you links:
http://www.dmlwheels.com/m-sport.html
http://www.dmlwheels.com/m-classic.html
I still dunno, sport or classic.
classic doesn't have 7.5, but they have 8.5 +20, not sure if 8.5 is good idea in front.
What about tires?
What about tires?
Okey:
M-Sport. Big lip option:
Front: 18x7.50 +43/48 (what u think will be better?)
Rear: 18x8.50 +35
M-Classic. Small lip option:
Or Front: 18x8.50 +20/32 (what u think will be better?)
Rear: 18x8.50 +32
I have no clue what tires specs will be better, so hope you will suggest something.
Rear: 18x8.50 +35
Rear: 18x8.50 +32
You really should FORGET about wheel fitments first and get an alignment FIRST..
Okey:
Rear: 18x8.50 +35
Rear: 18x8.50 +32
Rear: 18x8.50 +35
Rear: 18x8.50 +32
Did an alignment.
Any suggestions what should i buy as alignment kit?
I want to install them myself and then bring to garage to do alignment, so ball joint wont work. Or maybe you think it's better to buy balljoint for the front and ask them to install it?
Thanks!
Front C.:
L: 2°57'
R: 3°18'
Front:
L: -1°20'
R: -1°19'
Rear:
L: -2°02'
R: -2°25'
L: 2°57'
R: 3°18'
Front:
L: -1°20'
R: -1°19'
Rear:
L: -2°02'
R: -2°25'
Thanks!
Nighthawk Black Pearl
kind of old thread but didnt want to start a new. i have -1.5 camber in the fronts. My question is, do you guys think i can slide with -1.5? or would you guys recommend i get a camber kit for the front?
my alignment is way off, but when i took it in to get aligned all they could do was fix the toe which was off, they said i dont have an sort of adjustment for the front tires and alignment...can someone care to explain this. thanks again
rockyboy
12-06-2022 02:29 PM
nuldabz
09-03-2015 05:49 PM
